Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Smell of gas with no sign of leak...
I have a 90 runner with the 3VZE. Driving home from work today I kept smelling gas. When I got home I walked all around it and could see no signs of a leak, however when I popped the hood you could tell it was coming from under there. I looked all over that engine and could not find any sigh of a leak. The smell does seem to be stronger on the passenger side though. I did the search on here and found some similar issues but they seemed to have obvious signs of a leak (actual gas dripping). Any ideas where to start looking?
__________________
1990 4Runner, 31X10.50 Treadwright MTG's, Flowmaster exhaust, Skyjacker Nitro shocks, K&N filter, Weston push bar. I got your Jeep thing...Now it hurts when I pee. |
| Sponsored Links |
#2 (permalink) |
I just had to do injector seals for the same reason could not see it but smelled it realbad even brought my eyes to watering. Changed all the seals in the injectors no more gas smell and running better.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift Kit custom 6" coils rear lock right #1620 Rear Aussie Locker #xd-27527 front 5.29's Front And Rear 35 x 12.5 x 15 B.F.Goodrich KO's Micky Thompson Classic II Wheels 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only Streached 5.5 gal. tanks 16" Ape Hangers 3" open primary "Three People Can Keep A Secret If Two Peolpe Are Dead" Benjamin Franklin |
#3 (permalink) |
There is a fuel pulsation dampner on the end of the fuel rail underneath the intake plenum on the passenger side. Idk about yours but there is a little screw under the cap and it fell out of mine and caused it to catch on fire. Might want to check that.
__________________
-Mike 1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket Soon to come: New wheels and tires, Sliders, CB. One Day: 3.4 swap! www.myspace.com/222948743 |
#4 (permalink) |
Is there anyway to check the injector seals without removing them?
__________________
#5 (permalink) |
anyone?
__________________
#6 (permalink) |
I've heard about leaky fuel dampners being the cause for such a smell.
I'm having the same issue with my '88 3vze and I believe it is either the dampner--I'm not a mechanic, anybody got a pic or diagram or where the dampner is--or the fuel injectors are not installed correctly or are leaking. I'm curious to know what is involved with fixing injectors seals too, or the dampner possibility. Waiting for yota gurus/yodas to reply. Last edited by 88runnertx : 07-24-2008 at 12:25 PM. |
#7 (permalink) |
right around here for that fuel pulsation dampner
![]() Need anything else just ask.
__________________
#8 (permalink) |
x3 on the pulsation dampner...had same smell...that was the cause..
#9 (permalink) |
Oh to answer your question, it depends on what is wrong. No clue about the injectors, but for the dampener, the only two things i can think of is that it might be leaking from around the rim, or the screw fell out. If its the lip you will have to buy a new one. I personally just put red locktight on the screw and put it back in cause that was the problem with mine. Either way, it looks like you are pulling off the plenum and looking around.
Make sure you take care of it before it catches on fire, you don't want this happening! ![]() GOod luck!
__________________
-Mike 1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket Soon to come: New wheels and tires, Sliders, CB. One Day: 3.4 swap! www.myspace.com/222948743 Last edited by 904_runner : 07-24-2008 at 01:01 PM. |
#10 (permalink) |
Location: In the air, on the ground- hopefully makin your cellphone work better.
maybe also make sure the hoses to the charcoal canister are in place and good condition.
__________________
Knowledge is that thing people don't have that they hope others do so they can get out of trouble without having to learn anything themselves... It's time to re-claim 'green' as the color we deserve. Vote me as President, write-in candidate 2008.While you're at it, write-out EVERY Senator and Representative you can. join Yotatech chat at http://www.yotatech.com/misc.php?do=flashchat |
#11 (permalink) |
Thanks guys. That definately gives me a place to start checking.
__________________
#12 (permalink) | |
Quote:
p.s. if you need a new one, get a toyota one, don't get an off brand. I tried that but the only one they had was a hack job and had crappy threads. good luck.
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6 3vze, 5-speed, 31/10.50-15 toyo A/T, All Pro 1.5" coil springs, bilstein front shocks, doetsch tech mv12's rears, , MC heavy duty clutch feasable wish list: 32-11.50R ssr 4.88's ARB air locker Probably-not-going-to-happen wish list: JD fab 4wd long travel kit. other ride:2001 Honda XR400R
#13 (permalink) |
Maybe there should be a recall since this seems common!
__________________
#14 (permalink) |
you would think so, wouldn't you?
especially something that can cause a fuel fire. mine was dripping on my crossover exhaust pipe. so i could see smoke. that's how close mine was......to ![]()
__________________
#15 (permalink) |
See my above pics! Thats what caused that so You got lucky!
It was soo depressing for me, 16yrs old, first vehicle, catches on fire on the way home before i even got to drive it .Luckly, my grandfather was a mechanic so we ended up fixing it in the driveway with the help from the family! Only good outcome is i know a bit about the engine now! Now its just a braging thing! "250,000 miles, 3.slow, original headgaskets, been through a fire, you know its a toyota thing, lets see your "insert brand of vehicle here" do that!" ![]()
__________________
#16 (permalink) |
I don't know about the 3vze but just last week on my 22RE I had to replace the fuel sending unit located on top of the fuel tank because of a leak however I noticed the gas smell 3-4 days straight before the leak opened up enough to actually let the fuel drip on the ground try and see if the smell is stronger back near the gas tank area
__________________
1994 DX 4x4 X-Tra cab 55K original miles Eclipse Cd player Infinity Reference speakers Painted grill Black K & N FIPK Mobil 1 Mobileclean 5000- Purolator Filter |
#17 (permalink) |
Can't smell a thing towards the back of the truck. It is definitely coming from under the hood. The smell is strongest on the passenger side.
Again, thanks for all the tips guys. Hopefully I can find this thing soon. I bought a fire extinguisher yesterday...just in case!
__________________
#18 (permalink) | |
Quote:
__________________
#19 (permalink) |
![]() ![]() ![]() From what I can tell this is where it is coming from. Plan is to clean it all up today and let it run for a while and see for sure. But when I run my finger across it, there is more gas than oil. Anybody know what this is? It looks like it's just a fitting?
__________________
#20 (permalink) |
Woohoo! Gunk degreaser was on sale for $1.67 a can! So I stocked up. Now I have everything nice and shiny under the hood. Once it dries I'll go out and crank it and let it run for a while and see if I can actually find this leak.
Again, any help with letting me know what the above pic is would be great. I think it's just a fitting but then I'm an electronics guy. Under no circumstance do I consider myself mechanically inclined..lol.
__________________
#21 (permalink) |
looks like a bracket to support maybe a fuel line?
__________________
