shift levers interference
Ok, I was intrested in Philbert's seat replacement thread. I have his shifter combination currently. You can get a decent view if you scroll down that DIY thread.
In case someone missed it, I solved it by putting the main lever into neutral and pulled it in the direction of the driver's door. It bent maybe a 1/2" over, measured at the handle/knob.
It's been 2 days now and several trips on the highways and is still not hitting the t-case lever when I reverse.
I'm still amazed by how tight the throws are now: I can even tell that 5th and reverse a little bit farther right than I thought. Like, 1st and 3rd / 2nd and 4th are about 1.5" separated, horizontally, and 3rd and 5th / 4th and Reverse are around 2" separated.
my guess is that 20 or so years of shifting have gradually bent the shift lever in tiny increments, coupled with worn bushings.. when you put in the new bushings, the shift lever had been bent to suit the old bushing, and the new bushings corrected the lever location.
you can see the problem
Yeah, no real problems shifting through the gears, just that shifting to reverse makes the lever hit the transfer lever and if I'm not paying attention and don't move the main shift lever a little left when I shift to reverse the transfer lever will get bumped into 4HI.
The torch is likely to come out soon so I can heat and bend the main lever just a bit so that doesn't happen. I'm just waiting to see if anyone with more experience than I pops in and suggests something else.
punks_is_4x4
02-26-2016 04:29 PM
hiluxinargentina
09-30-2015 05:51 PM
