Setting Timing Issue
Old 10-26-2018, 11:42 AM
Michael Topping's Avatar
So I have read all the stickys...and the FSM..and searched and read multiple threads none express the problem I am having.
1995 3VZE 120k 4x4 auto
- Bought the truck, was running on 4 cylinders.
- discovered improper valve lash
- adjusted all valves to correct clearances.
- eliminated egr
- inspected all vac lines.
- new upgrade plugs, wires, cap and rotor
-when I go to set the timing I jump TE and E, CEL flashes, as there are no codes, however the motor timing never changes. problem thou is that when I hook my timing light up to #1. The timing mark slowly rotates counter clockwise around and around. never locks in position.
I have set the timing by ear and it runs great.
My question is why does it not lock/set in place to record an accurate reading?
I have ohm'ed the follow:
TPS, Distributer, Ign, AFM, TPS-ECM and all are within spec.
Any ideas?
Old 10-26-2018, 02:28 PM
scope103's Avatar
I doubt it is a problem with your truck. Occasionally people have a harmonic balancer with a failed rubber annular ring, but that should just produce a constant offset. If it was "spinning" on the Harmonic Balancer, you'd know it.
So the only way to get a slowly moving timing mark is if your timing light is auto-firing at a frequency that is slightly different than the rotational speed. I don't know much about timing lights with settable advance (mine runs on kerosene); do you have settable advance? Try setting it to zero. Try gently accelerating the engine to see if you can change the speed of the "rotating" timing mark.
Old 10-26-2018, 03:22 PM
Generic timing light. No setting just plug to battery and to #1 push and hold button. All my other cars I can do with my computer.
I have read about the set key possibly being broke but like you said I'd know it.
I may remove belts and check balancer
quick2300
10
12-13-2010 12:02 PM
wishmaster22
07-12-2006 10:03 PM
da_bigg_wigg
04-14-2006 08:11 PM
4Rocker
02-06-2006 07:43 PM
jchef
12-18-2002 11:34 PM
Quick Reply: Setting Timing Issue
