screw part on intake
Dont know the correct name for it. Its left my head. Just looked at it at the parts store.
Should all the passages be able to be blown through? I took it off to clean it, check it out and all nozzles except the one on my thumb. Under it. Will allow me to blow air through. That one wont let me. Like its stopped up.
Is it supposed to be or is it clogged?
Picture wont upload, still trying.
Its the part on dtiver side of intake. Behind tb. Screws into the intake with a adjusting screw with spring on top with 4 vacuum lines on it. The one on the bottom is the one im talking .about
You might want to try this one again. Even with a picture, I'm not sure I could follow your question.
Knowing which engine you're talking about could help. And I'll bet you could even find a drawing of that screw in the manual. http://www.ncttora.com/fsm/1990-1995...e/throttle.pdf
Ok idle up valve. Not the name i was thinking of it. Thank you for the picture .reference...
Is all 4 vacuum lines need to be clear and able to blow threw them
Use this pic. Which line is 'clogged'?
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
skoti89
07-06-2015 07:45 PM
