Replaced oxygen sensor, now it idles horribly.
Here's something interesting to chew on......
If you ran a search, you'd find a lot of threads discussing this issue. I've not seen any that's mentioned this "wind band" idea, but all threads say the same things. Most have problems with Bosch units while it seems there is there is few that don't. (Maybe a determining factor is if the one's that don't have a secondary/post cat sensor.....not sure). One issue, with the 22re atleast, is the sealing flange on the Bosch unit is too large for the manifold port on early designs. But, the other debate is the length of the sensor probe. The Bosch is supposedly too short to accurately sample the exhaust. Now, I've always had problems with that theory. To prove my point, don't know if anyone here's ever noticed, but an NTK replacement (which is a Toyota recommended option in lieu of a Denso unit) has the same length and diameter of probe that a Bosch unit has. I ran an NTK for years on my '86 4rnr after I acquired it. The engine ran fine, but I almost never got 20mpg's out of it. The only time I did was with 31" tires. Go figure! But, even then, it wasn't consistant. Now I have a brand new Denso unit. The probe is atleast a 1/4" longer and large in diameter. In fact, I had to actually carve the carbon deposits out of the manifold port to even get it to fit. It's a snug one! And, now, I consistantly get an average of 20-21mpg's. The engine doesn't run any differently, though, from what I can tell. Same power and smoothness, just better fuel economy. So, I'm going to explore the "wide band/narrow band(?)" idea further. The frequency has got to be the difference.
And, of course, I suppose there would be possible differences between heated and non-heated units, but I'm really thinking not.
Come to find out the wideband sensors were invented by Bosch. They are supposed to eliminate lean/rich cycling that narrow band sensors have.
Nice little Wikipedia article here: http://en.wikipedia.org/wiki/Oxygen_sensor
Edit: I did find that (at least according to internet pictures/description) the NGK/NTK have a flange that can be unscrewed and the sensor can be used with a screw-in bung fitting on the pipe. However; I can not find a parts store in my area that normally stocks these things.
#26
Yeah. I'm not sure if the O2 sensor is even the problem in my truck anymore. It's looking more and more like the IAC (Idle Air Control). Which means new TB? I might be able to adjust the throttle stop screw to get it to idle a little higher, then re-adjust the TPS for the millionth time.
#27
#28
There is an Idle Air Control - as far as I know, it's controlled by the engine temperature and an adjusting screw (which is set all of the way open) I don't think it's electrical. I'll look through my FSM tonight.
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
