Replaced oxygen sensor, now it idles horribly.
Old 09-07-2010, 08:27 PM
prerunning4x4's Avatar
1991 Pickup, 3vz-e with 4wd.
Check engine light threw a 5 code, oxygen sensor. Replaced it today and now it idles like ass. Do i just need to have my ECU reset? How do i go about fixing this? thanks
Old 09-07-2010, 08:42 PM
myyota's Avatar
What brand of 02 sensor did you buy ?. If you bought a Bosch 02 sensor that could be the problem, most toyota`s don`t like Bosch 02 sensors.
Old 09-07-2010, 08:44 PM
Ahhhh, it is a bosch, what do i do?
Old 09-07-2010, 08:52 PM
myyota's Avatar
You need to get a Denso 02 sensor, Denso is an OEM part. I don`t know what the deal is with Bosch 02 sensors, but most of the time they make our toyota`s run like crap. Just for the heck of it disconnect the battery for a few minutes and see if that helps.
Old 09-07-2010, 08:55 PM
Okay:/ i just dont know if over time it will start working effectively though?
Old 09-07-2010, 09:04 PM
myyota's Avatar
unfortinatly it won`t, you can try driving it the way it is for a while, but im guessing that your mileage is going to suffer. The computer uses the 02 sensor to set the air fuel ratio, and if its not working properly your mileage and power will drop.
Old 09-07-2010, 09:08 PM
But that's weird, because power was fine. Even better! i dont get it... I guess ill throw the stock one back in, just to do some wheeling i planned on before and figure the rest out tomorrow.
Old 09-07-2010, 09:16 PM
myyota's Avatar
Im just going by what ive read here and what ive personally seen. When an 02 sensor goes bad the signal it puts out gets weak causing it to throw a code, thats probably why it ran better with the new Bosch 02 sensor. I wish i had more info on why the Bosch 02 sensors don`t work well in toyota`s, but i don`t.
Old 09-07-2010, 09:26 PM
Stupid bosch, well the old one is back in, and i will order a denso tonight off of autopartswharehouse, for cheap. I upped the idle speed about 90-160 degrees ( dont remember.) but its running solid for a 230k rebuild that sat for months.
Old 09-07-2010, 09:27 PM
Thanks so much for your help man.
Old 09-07-2010, 09:34 PM
myyota's Avatar
Another good place to get parts from www.densoproducts.com .
Old 09-07-2010, 09:57 PM
i just ordered from there! 68 USD with a 10% discount cuz i searched coupons!
Ill return to O'Reillys tomorrow with some lip action, thanks man. Youre awesome.
Old 09-09-2010, 09:14 PM
Denso in.
Works like a charm, idles like a champ. Thanks man.
Old 09-09-2010, 09:23 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
right-on...
And on a side note, 80 series Cruiser guys on mud have reported using a "wide band" O2 sensor has had worse effects than running a OEM sensor...
Can't recall if the "Wide band" is a Bosch or not.
Glad you got it...
Good call, myyota
remember kids:
......................................OEM
Old 09-09-2010, 09:49 PM
I dont know, i am just so glad to have no lights on the cluster.
Trooooooof on the oem, no joke. Ill always keep that in mind now.
Old 09-09-2010, 11:57 PM
myyota's Avatar
Denso in.
Glad to hear that it worked out and is running good once again.
Old 09-10-2010, 08:02 AM
You are a life save my friend.
Old 09-10-2010, 08:12 AM
BajaRunner's Avatar
Just curious which part # did u get?
Old 09-10-2010, 10:10 AM
Following is a summary of your order:
1 - Denso OE identical O2 sensor
Stock Number: 234-4055
Part Number: 234-4055
Unit Price: $48.49
Extended Price: $48.49
Old 09-10-2010, 10:34 AM
dieselloco427's Avatar
Wow - this could be my problem I've been having too. I bought a Bosch from PepBoys (about $100 - yikes!!!) after my rebuild. I'm going to order a Denso right now!!!
Quick Reply: Replaced oxygen sensor, now it idles horribly.
