replaced oil cooler seals today
Old 07-15-2015, 03:57 PM
mark3913's Avatar
Hey Jason, Thanks for the good details, am planning to do this job this week. Question: if I want to take the oil cooler off but leave hoses on can I just crimp the lower to save the coolant and just disconnect cooler from the top{water} do I need to crimp that one also,can't imagine much water pumping out.Thanks for your help.
Mark
Truckee,Ca.
Old 06-17-2018, 03:23 PM
Paul H.'s Avatar
Bringing back an old thread but mine is now leaking pretty bad on start up so it looks like I will be replacing the seals. A couple of questions first: do I need to drain the oil and coolant? Also is the part number for the seal kit 1036? Thanks in advance.
Old 06-18-2018, 12:37 PM
mark3913's Avatar
Paul, I just replaced the Oring and gasket where the bolt goes thru. I drained the oil but did not remove the coolant lines so didn't need to drain the coolant. the Oring # is 90301-61003 and the gasket is #15785-35010. I changed them without taking the cooler out by leaving coolant lines attached and working with a small needle nose pliers and a dental pic,quite easy to do.Both were pretty rotten and with new gaskets it doesn't leak a drop in well over a year now. Hope that helps.
Mark
Old 06-24-2018, 04:21 PM
Paul H.'s Avatar
Thanks Mark, I found the seal kit, 3 seals, on Ebay for around $13.
Old 07-08-2018, 05:30 PM
  #25
Paul H.'s Avatar
Well I finally got around to doing this today as the weather finally improved enough to not sweat buckets while working. Anyway, I took off the tire and heat shield and what a pain in the butt it was to change those seals especially the large one. I left the cooler attached and trying to get the seal under the tabs with so little room was a major pain. All told it took me about 2 hours from start to finish but thankfully it worked and happy to report, no more leaks. I also left the oil in and only lost about 1/2 a quart at the most.
Old 03-09-2019, 09:19 PM
  #26
Kalihi,HI's Avatar
So I removed the oil cooler and the upper pipe/tube that connects with the smaller u-shaped rubber hose to the engine was full of orange/brown sludge and so is the pipe coming from the engine. I was able to clean out the oil cooler with brake cleaner and compressed air, but what is the best way to clean/clear out the pipe/tube coming from the engine? Pour distilled water down the radiator and hopefully it cleans it out? Any help is appreciated.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: replaced oil cooler seals today
