Removing timing gear from crankshaft
Old 05-19-2006, 04:58 AM
jjenks0's Avatar
Any ideas on how to remove a stuck timing gear from the crankshaft?
Old 05-19-2006, 06:40 AM
eric-the-red's Avatar
I pried mine off with 2 big screwdrivers. Put one on each side with the tips behind the gear, pad the block with some rags and push back on the handles. That moved it far enough to get a small puller in there to finish the job.
Old 05-19-2006, 06:49 AM
snap-on's Avatar
same hear (screwdriver)
but watch it, the oil pump (directly behind the gear, what your prying against) is AL and in theory you COULD crack it.
both the ones ive taken off werent stuck on THAT hard.
Old 05-19-2006, 04:41 PM
subliminaltrips's Avatar
ill 3rd the screwdriver trick. also a little fine grit sandpaper on the little key in the crankshaft make it alot easier to get it back on. mostly just enough to remove any burs.
Old 05-19-2006, 07:22 PM
He may know his 22re's just fine but the original post was about a 3.0 V6, where you don't have to remove the oil pump to get at the timing gear.
Old 05-19-2006, 08:11 PM
snap-on's Avatar
well as he specificly didnt say... i suppose it could be either... but the sig lists the 3vze
and the 3vze has an oil pump mounted to the front of the block, then the crank gear, then a retainment washer for the TB, then you have to put on a black plastic cover, then comes the crank pully, then a big arse bolt that needs 180ftlbs.
and this is what happens when you dont get the crank pully on correcly
trust ME i know my 3.slow
Old 05-20-2006, 03:57 AM
ovrrdrive's Avatar
Yep, I should have caught that... I was just feeling like being a smartass for some reason.
I even read the post a few times too. Sheesh, guess I was up too late.
Old 05-20-2006, 07:59 AM
I have one like that too, I keep it in the garage as a reminder not to rush and double check things
Old 05-20-2006, 06:08 PM
Chuki's Avatar
^^^ That'll happen if I don't torque the crankshaft bolt down to 180ft-lbs?
My torque wrench I think only goes up to 150.
Old 01-08-2024, 01:57 PM
Makiahblue's Avatar
Fix?
Just ran into this issue, what’s the fix?
Old 01-08-2024, 06:01 PM
BBQ Tables's Avatar
I can't believe you found an 18 year old thread to post this question in!
I guess that shows how rare this issue is with the crank woodruff key and the timing belt sprocket.
If your crank looks like that, you might be able to just replace the key and the gear and get it going again.
If you have a lot of wear on the crank snout where the balancer sits, you should replace the crank (and balancer).
The damage on the end of the crank is actually more worrisome than the woodruff key and the sprocket.
Old 01-11-2024, 08:06 AM
Makiahblue's Avatar
Thank you!!!
y’all are amazing!!! I’m 23 and running into this ˟˟˟˟ back to back and couldn’t find any info
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
85run
07-08-2015 11:20 PM
metalmadness24
07-01-2015 10:21 AM
hexrain
06-27-2015 06:17 AM
Quick Reply: Removing timing gear from crankshaft
