Rebuilt 22RE idle and O2 sensor issues.
Old 10-22-2009, 02:58 PM
YFZsandrider's Avatar
After getting my 22RE rebuilt, it seemed to run great at first, but now the idle is all screwy. After a short drive, I noticed the problem, so I brought it back home, and the idle was sitting at around 1100 RPM, so I adjusted the idle screw down to around 750.
The problem I am having is the idle surges at times, and often when I pull up to a light, it will remain high, unless I tap the gas pedal to get it to jump, then lower down to where it should be.
What is the proper sequence for all of the throttle body adjustmant screws?
Also, I do not have the O2 sensor hooked up, as the prev. owner had it un plugged and the plug layed against the exhaust and melted enough to distort it. WHat O2 sensor shoud I run in this? Its a '94 22RE.
Old 10-22-2009, 03:56 PM
bend's Avatar
For the 02 sensor go with either denso or NGK.
Old 10-22-2009, 04:49 PM
kornhuskerwizard's Avatar
is there a vacuum switch under the throttle stop?? Mine idles high unless i mess with that vacuum switch...
some drunk guy
08-03-2021 06:09 PM
Firefightersink15
11-23-2015 10:32 PM
shredder4286
10-01-2015 01:09 PM
sonorn67
09-19-2015 05:39 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Rebuilt 22RE idle and O2 sensor issues.
