Radiator fan blades warped=vibration in front of engine bay?
Old 04-21-2010, 07:32 AM
Mr.Matthew3's Avatar
Originally Posted by buckz6319
what the hell is around the outside of the fan blade??
Not sure what you're refering to. You mean how it's not just the blades? With the ring around the edges?
Old 04-21-2010, 07:40 AM
toyminator2000's Avatar
ALL OF THE 3.0 V6 FANS LOOK LIKE THAT. AS I SAID BEFORE. YOUR FAN IDLER BEARING IS GOING BAD. THIS IS CAUSING THE FAN TO WOBBLE AND AND TURN UNBALANCED, CAUSING THE WARPED LOOK YOU SEE IN THE VIDEO. IF YOU DON'T REPLACE IT SOON IT WILL EVENTUALLY BREAK SENDING FAN PARTS THROUGH YOUR HOOD, RADIATOR, AND POSSIBLY OTHER IMPORTANT THINGS. THEN YOU WILL GET TO REPLACE THE IDLER BRACKET ALONG WITH THE FAN AND ANY PARTS IT TAKES OUT WHEN IT BREAKS.
HERE IS WHAT YOU NEED, ALTHOUGH I WOULDN'T RECOMMEND BUYING IT ON EBAY.
http://cgi.ebay.com/ebaymotors/1990-...Q5fAccessories
The following users liked this post:
stryker30 (03-05-2024)
Old 04-21-2010, 07:48 AM
Toyminator2000-
Sorry, for some reason I thought you were talking about the fan clutch bearings and was about to tell you that it was recently replaced. I didn't think about the Idler pulley. Ill check it out. But like I said,the fan its self looks severely warped. If it is indeed the fan causing the wobble, would the 22re fan be sufficient to cool the 3.0?
Old 04-21-2010, 07:53 AM
probably not. If it was it would be the same fan to begin with. Besides, you are already missing your shroud, unless you took it off for the video.
Also, the balancer moving in and out is probably actually the crank itself moving in and out. not easy to fix.
Old 04-21-2010, 07:57 AM
  #25
Yeah I haven't gotten a new shroud yet, the old fan took it out when it shattered. I figured it wouldn't be enough to cool the bigger engine, but I figured I'd ask. The salvage yards around here have very few Yotas, and what they do have, only have the 22re engine ha.
But yeah, I'll look into the Idler pulley.
Thanks guys
Old 04-21-2010, 08:00 AM
  #26
mt_goat's Avatar
I agree get a new fan bracket before this happens to you:
https://www.yotatech.com/forums/f116...d-part-143611/
https://www.yotatech.com/forums/f116...-3-0-a-105823/
https://www.yotatech.com/forums/f116...-words-145323/
https://www.yotatech.com/forums/f116...hotgun-164748/
https://www.yotatech.com/forums/f116...lew-up-169630/
If you go with a cheap made in China part, I'd recommend not mounting a mechanical fan on it and switching to a Taurus fan.
Old 06-02-2023, 11:57 AM
  #27
Scottafb's Avatar
Looking through threads for vibration issue
I have an 89 Extended cab (4x4) pickup with the 5 speed manual transmission. It has always had a vibration since buying it a year ago
hat makes itself known when the engine hits 3400 RPMs. The odometer is at 192,000. I had an 08 Tacoma that
had a similar vibration that I narrowed down to a poorly written factory tune for the variable valve timing. This 89 feels like dry bearings in a
U-joint. But, It happens at 3400 rpm and higher in every gear. I am easy on it and never drive over 68 mph.
Old 07-04-2023, 01:03 PM
  #28
Scottafb's Avatar
Could be a loose/bad motor mount.
Jmiller1023
23
08-06-2015 07:03 PM
noahstancik
07-10-2015 11:18 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Vargntucson
07-04-2015 12:15 PM
2wdtundra
06-18-2015 05:19 AM
Quick Reply: Radiator fan blades warped=vibration in front of engine bay?
