Quick question regarding crank/cam/chain alignment 22re
Old 02-06-2008, 05:41 PM
91Toyota's Avatar
If looking at the top without the timing chain cover removed...if the camshaft mark is up and the piston (#1) is at the very top (top dead center)....does that mean it is aligned?
Old 02-06-2008, 05:49 PM
Brennan's Avatar
No, it should be slightly off to the passenger side of the vehicle, you want to align the pin that sticks out of the spacer thats between the head of the bolt and the cam sprocket itself.
Old 02-06-2008, 05:55 PM
91Toyota's Avatar
It's just BARELY off to the left though...right? But, would you say it is aligned?
Old 02-06-2008, 05:57 PM
YotaJunky's Avatar
Yes, that's right. Like the previous poster said, it will look like it's off to the left slightly. Also, check the FSM to make sure the correct rocker arms are able to slide during the compression stroke.
Old 02-06-2008, 06:13 PM
91Toyota's Avatar
Sorry, but what is FSM? Thanks
Old 02-06-2008, 07:43 PM
javadoody's Avatar
FSM is the factory service manual. use http://personal.utulsa.edu/~nathan-buchanan/93fsm/ if you don't have one.
he basically means to be sure #1 is in compression with the mark at around 11:00, or slightly off to passenger side of vertical. if both intake and exhaust rockers are free (not holding open the valves), you're in compression.
Colington
03-08-2020 09:51 AM
jasonty
41
12-23-2018 01:00 PM
coleypull15
11-03-2015 07:41 AM
icentropy
07-14-2015 10:23 AM
hangtown88toy
07-10-2015 02:33 PM
Quick Reply: Quick question regarding crank/cam/chain alignment 22re
