proper vafm swap for the 3vze
Old 07-07-2011, 08:28 AM
Asuarez737's Avatar
Is the 7mge bigger than the 3vzfe?
Old 07-07-2011, 09:30 AM
MudHippy's Avatar
7M-GE & 3VZ-E
3VZ-FE
I've only heard of 2 sizes. Like I said though, I have no way of verifying that. The 7M-GE is the same size for all I know.
Originally Posted by Toysrme
Small Denso AFM housing has been rated 165CFM @ 0.74in.Hg
Large Denso AFM housing has been rated 200CFM @ 0.74in.Hg
3vz-e AFM is not too small - proven via math!
Old 07-07-2011, 09:56 AM
eric924run's Avatar
What would be the point of changeing meters unless you changed the need air volume i.e. supercharger or big cams.
Old 07-07-2011, 10:06 AM
RBX
RBX's Avatar
I would think it would make the biggest impact at wide open throttle, only because of the immediate availability of air volume. So that should net you a snappier throttle response. I am just talking out of my... i have no real proof.
Old 07-07-2011, 11:23 AM
  #25
MudHippy's Avatar
Good question.
Keyword: Volumetric Efficiency
If you haven't modified it from stock significantly. You won't gain much, if anything. Any power gains from increased air flow would likely only be in the mid-high rpm range anyways even if you did modify it.
Airflow vs HP
Engine airflow can be directly related to hp developed. The volumetric efficiency of an engine is always the highest at its torque peak. Above this rpm, pumping efficiency drops off.
The whole AFM swap thing for these engines is pretty much a joke to me. And some who've done it. Not to to say I never would. What I mean to say is, it would be one of the last things on the list of things I'd do to a 22R-E or 3VZ-E to make more power. I do however, as Toysrme also suggests, recommend tuning the A/F ratio with the stock AFM and advancing the initial/base ignition timing on the stock/nearly stock 3VZ-E. There's your throttle response and low-high rpm power gains right there. Cheap and easy. WORKS FOR ME!
I did my research FIRST too, as usual...
Old 09-20-2013, 08:12 PM
  #26
skipper0802's Avatar
Eureka!
Originally Posted by runnermedic
which vafm to look for?
talking about the oem part numbers.
22250-62020-camry ,lexus v6
22250-74180-celica 3sgelc engine
22250-43230-cressida 2.8L
22250-43150-supra 5mg
22250-61010,22250-75020-land cruiser
22250-74100-previa non s/c
this page contains all toyota vafm oem numbers
http://www.autoairflowsensors.com/index.php
I finally found the part list...
Old 10-17-2013, 04:07 PM
  #27
Slowey23's Avatar
22250-74140 also works, it's off a camry 3sge engine
Old 10-17-2013, 04:17 PM
  #28
bone collector's Avatar
put a 4 cylinder afm on a v6 motor and expect improvement?? I would need to see some proof on that
Old 03-14-2015, 09:45 AM
  #29
teaMJPx's Avatar
Been looking for this list for a while. Thanks OP!!!
*** BUMP ***
RatOmeter
10-22-2015 03:17 PM
91yotapup
07-27-2015 07:19 AM
whereAreMyPants
07-22-2015 03:32 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: proper vafm swap for the 3vze
