oil cooler removed? 3vze
Old 01-11-2008, 12:32 PM
mrnick1979's Avatar
Cool oil cooler removed? 3vze
i just was wondering if you can completley remove the oil cooler from the engine? maybe replace with an oil filter? i think the one that is on the engine i just tore down is bad. i found coolant in the oil, i couldnt find any signs of a blown head gasket or any crack anywhere.has anyone else had or herd of one going bad?
Old 01-12-2008, 01:22 AM
idanity's Avatar
i thought the radiators extra cooling port was for the tranny fluid (automatics).
and, oil coolers are great, i would love to have one.
Old 01-12-2008, 04:28 PM
mrnick1979's Avatar
the cooler on the side of the block not the radiator.
Old 09-15-2009, 11:37 AM
vandert's Avatar
What ever came of this, I need to replace my oil cooler gaskets and have been thinking of changing the setup or doing someething different like this.
Old 03-09-2019, 09:43 PM
Kalihi,HI's Avatar
So I removed the oil cooler and the upper pipe/tube that connects with the smaller u-shaped rubber hose to the engine was full of orange/brown sludge and so is the pipe coming from the engine. I was able to clean out the oil cooler with brake cleaner and compressed air, but what is the best way to clean/clear out the pipe/tube coming from the engine? Pour distilled water down the radiator and hopefully it cleans it out? Any help is appreciated.
09-04-2015 09:27 AM
88yodabasket
07-13-2015 01:32 PM
Coreyr384
07-10-2015 11:13 AM
Snort
07-09-2015 03:58 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: oil cooler removed? 3vze
