Which O2 Sensor?
Old 06-16-2012, 03:25 PM
steelgtr's Avatar
Which O2 Sensor?
Hi Guys
I have a 1991 22RE SB pickup, Cali truck. I need the rear (after CC) O2 sensor and I'm looking for the right replacement. Amazon has a quite a few that "fit my vehicle" but they don's say Cali vehicle, before or after, etc?
I think this is the one I need but I could use some help first!
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Found the part number from here:
http://www.autopartsnetwork.com/cata...ase_year:1991_
thx
bob
Old 06-16-2012, 04:33 PM
combatcarl's Avatar
I had a similar issue finding one for my truck. Go to toyodiy, input your vehicle, get Toyota part number. Then find Toyota to denso cross-reference, (can't remember where, think I googled til I found one)find denso part number, and shop by that. Eventually, I found the right one. Bout a half hour of searching and confusion, but it worked out.
Old 06-16-2012, 09:26 PM
Dirt Driver's Avatar
Both sensors are the same AFAIK.
Old 06-16-2012, 11:15 PM
abecedarian's Avatar
I just checked on my 91 22re truck and
http://www.autozone.com/autozone/par...mString=search
pre-cat sensor and post-cat sensor are the same if you use Bosch... but different if you use Denso.
That may have something to do with if the sensor comes with a pre-installed pigtail (denso) or not (bosch).
Old 06-17-2012, 02:31 AM
iselloil's Avatar
Go to the denso web page and get there listing, then you cand search it on amazon.
Old 06-17-2012, 05:36 AM
steelgtr's Avatar
Found it but how do I know which sensor is after the CC?
89465 SENSOR, OXYGEN
89465‑39226 VZN85..IV6; RN8*, 90, VZN95..(4HC, 5F)..EFI 1 $250.07
89465‑39236 RN80..(4HC, 5F)..EFI..USA, CALIFORNIA SPEC, NO.2 1 $250.07
89465‑39286 RN8*, 90..(4HC, 5F)..EFI..USA, CALIFORNIA SPEC, NO.1 1 $250.07
bob
Old 06-17-2012, 10:25 AM
You can narrow it down to the CA-spec parts.
Old 06-17-2012, 11:09 AM
steelgtr's Avatar
Yeah, but there is a front and a rear and they are not the same.
Old 06-17-2012, 01:35 PM
combatcarl's Avatar
CA spec no. 1 is front, no. 2 is rear. Near as I can tell, could always run the part numbers past a dealer?
Old 06-17-2012, 05:12 PM
steelgtr's Avatar
Thanks,
Looks about right.
bob
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Which O2 Sensor?
