not sure which msd coil I need for 22re?
Old 03-20-2011, 07:14 AM
tim a.'s Avatar
Do you guys use the blaster2 or blaster3.If you use the three how do you attach the coil lead.Just put some new wires on the truck and shocked at how much better its running,figure I will replace 20 year old coil next.Thanks for help.
Old 03-20-2011, 11:34 AM
gamudslinger88's Avatar
I have a blaster 2 that I'm thinking about putting on. I also have a msd 6A I have been thinking about putting on too but I can't figure out how to wire it on these trucks. Anway to answer your question from what I can tell the blaster 2 will work.
Old 03-20-2011, 01:17 PM
peow130's Avatar
Neither.
The MSD coils aren't good on these trucks, and honestly won't help with anything.
You're better off with a new cap/rotor, and some good plugs.
Advance the timing a bit and set the gap a little bit wide, and it'll be a tad more efficient.
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Numberonedad6
07-30-2015 07:10 PM
konah
07-30-2015 02:08 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: not sure which msd coil I need for 22re?
