Need help with code 5 on my 87 4 runner 22re
Old 02-02-2009, 07:41 AM
my1987toy4runner's Avatar
Question Need help with code 5 on my 87 4 runner 22re
I have replace my o2 sensor 2 times now and it still is throwing code 5 (oxygen sensor signal) My check engine light only comes on mainly on the highway/freeway at a steady speed/rpm +/- 500rpm.
I use denso o2 sensors and thier direct fit oe ones too. The wiring is all good as well.
I don't know what to do please help....
Old 07-10-2023, 07:09 PM
pimacdaddy's Avatar
Ever found the issue ?
Old 07-12-2023, 12:33 PM
87-4runner's Avatar
That's a lean situation... you can change the AFM and stop that from happening. I know because I've done it.
Old 07-16-2023, 12:14 AM
84sr5yoty's Avatar
You have a vacuum leak. DO NOT F- around with the AFM to compensate. Check all of the vacuum motors with a vacuum pump, then grab a cigar and....
my1987toy4runner
02-23-2009 04:23 PM
Kindervb
02-05-2008 04:45 AM
onesojourner
49
01-19-2008 08:00 AM
kawicowboy
11-10-2007 01:51 PM
thegreydog
04-08-2007 08:04 AM
Quick Reply: Need help with code 5 on my 87 4 runner 22re
