Is my 4runner using that much oil?
what about going to 20w-50? my mechanic said back then, that is what they used to run in all of them. what do you all think? could it help?
what about that stuff called slick 50? engine restore? anybody ever use it?
he said the only other option is to go in the engine and rebuild it. to be honest with you that is what i would really like to do. that way i know it is good!! what all is entailed with that?
I've noticed a wierd phenomena that happens after every oil change on my '95 pickup with the 3.0 V6.
I'll put in 4.8 or 5 quarts per the manual. It'll be full after driving, but within 500 miles I'll be down about 1/2 a quart. Then I'll add the 1/2 quart, and I'm good for the next 2000 miles, when I might need to add another 1/2 quart. It's very odd. Happens every oil change. Some have suggested the filter is absorbing oil, but I don't think it absorbs that much!
MadCityRich
MadCityRich
How many miles are on your engine?
Mine burns about 1 qt to a half a quart between trips to the gas station. I know that it's my rings not sealing well because the head is rebuilt.
Have someone stand behind your truck while they watch you drive away. I've tried that before and people can barely see a blue haze. I can also smell it if I'm really heavy on the throttle or lugging.
A little oil consumption is the price we pay. Most engines of different manufacturers that get to the same mileage of the average 22re on Yotatech have alot more issues than burning a little oil.
You can always change your oil more frequently, it's cheap insurance.
so what about 20w-50 anybody? good idea?
#25
I talked to my local machinist about Engine Restorer and he said that's the only stuff he would add to the crankcase besides motor oil. I know I've recommended it to others and it has almost always curbed all oil consumption. If the majority of the oil is leaking past the valve seals, then it may not work very well as it's geared towards ring seal.
#26
Originally Posted by 84sr5yoty
From what Kyle_22r said, 20-50w was the oil Toyota called for way back in the early 80's, although my 84 recommends 10-30. It would be worth a shot anyway.
what all am i looking at to get the engine rebuilt? costs for parts? etc...
#27
did you mention what your current milage is, mpg that is? i had an old yoter that burned one quarter per gas tank. but the thing got 32-34 mpg, no sh^t. i decided that it was more economical keep a case of cheap oil in the bed than to rebuild. drove it like that forever. just more food for thought.
#28
my mpg is very very bad. i don't think i can go 200 miles on a tank of gas. i have an automatic so i am not sure if that has anything to do with it. i have not tried to calcualte it but i know my gas mileage is really really bad!!!!!!!!!!!
