MegaSquirt DIYPNP Your 22RE - The Tutorial!
Old 10-31-2013, 02:54 PM
  #61
Gamefreakgc's Avatar
The builds that were doing this had a turbo on it. Not really worth it for a naturally aspirated engine, much less something as small as a 22RE. Lot of $$$ for little gain.
Old 10-31-2013, 02:57 PM
  #62
85toy4runner's Avatar
ok thanks guys thats what I was thinking to, but wanted to make sure .
Old 03-31-2014, 09:04 PM
  #63
chuckles's Avatar
has anyone made progress with the MS/VAST timing variance issue? I have PNPMS2 and using Vast on 85 22RE Stroker setup with 11:1 CR. Too much ping even at 20 degrees. I have noticed that when running fixed 20 degree in MS, it is pretty close on timing light at idle, but when increasing rpms, the timing starts to fluctuate up to 10 degrees. Usually it's in the retarded direction, but it can spike 10 degrees or more advanced. Any tips? Have tried leading edge, but that just makes it run worse and miss. Have increased latency up to 50, and also tried dwell at 4 degrees.
Old 07-02-2016, 11:18 PM
  #64
Rolliecc's Avatar
I'm running the ms2 on 22re turbo and looking for a tune un able to find anything. Hopping some one can help
Old 01-13-2017, 09:15 AM
  #65
92 Toyo's Avatar
Is this basically a build thread of you building your own megasquirt? If I remeber right the megasquirt ecu pnp is only like 700 dollars of so?
Old 02-07-2017, 02:45 PM
  #66
dno
dno's Avatar
I've been running Megasquirt DIYPNP on my 4Runner for several years now. I haven't had any issues with timing. I did have a fuel injector adjustment issue until I switched to high impedance injectors. They are easier to set. The other issue was the injector setting had to be 2 squirts alternating instead of simultaneous.
Old 06-05-2018, 08:34 AM
  #67
22R4EVR's Avatar
Finally got Megasquirt PNP running on my 90 runner. It really makes the engine come alive. Now I am looking forward in hooking up a wideband O2 to the existing oxygen sensor connector so I can use tune analyze live. Any idea what wire to tap into. Its a 4 wire connection as the oxygen sensor is heated. Any help would be greatly appreaciated!
Old 06-05-2018, 05:19 PM
  #68
Windsor's Avatar
The two wires that are the same color (brown on mine) are the heater wires. What's left (black and red on mine) are the O2 sensor "data" wires. For me, black is ground, red is data.
JNapolitano
11-14-2019 07:46 PM
ia02
08-20-2015 11:04 AM
pyramid
07-30-2015 10:05 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: MegaSquirt DIYPNP Your 22RE - The Tutorial!
