Manual Transmission Oil for 22RE
Old 06-10-2010, 09:36 AM
livehho's Avatar
Toyota Pick-Up 22-RE 1995 4x4 128K miles
In the Owner's Manual says to use:
GL-4 SAE 75W-90
Where I live the only one they sell is Castrol EP 80w Manual (GL-4)
Is it safe to use SAE 80W instead of SAE 75W-90 ???? is there a big difference?
Old 06-10-2010, 09:40 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Unless it ever gets cold there, I don't see any real problem. Run a search on Redline MT-90, though. That's really good stuff. Butter for the tranny and ftw.
Old 06-10-2010, 09:58 AM
iselloil's Avatar
AMsoil or mobil 1
Old 06-10-2010, 10:15 AM
thook's Avatar
You know, Amsoil is good stuff and I've used that in the past. It's just harder to acquire. I've also used M1, but I tell you my tranny feels much better with the MT-90 than it ever did with the M1. Not that it was all that bad, but it felt stickier and a little harder to shift under certain conditions. It was full synth GL 4/5 rated.
livehho's Avatar
Originally Posted by iselloil
AMsoil or mobil 1
Yeah iselloil.. I know the oils below are the best ones for my ride..
Motul Gear 300
Castrol Syntrax GL-4
Redline MT90 GL-4
Royal Purple ‘Max Gear’
Amsoil Severe Gear 75W-90
Mobil 1 Synthetic Gear Lube LS 75W-90
However, that is not the question I asked.. but thanks anyway
Old 06-10-2010, 10:17 AM
livehho's Avatar
Thanks thook. Yeah I agree. I live in a hot weather. I guess I'll go for the 80W GL-4
Old 06-10-2010, 10:18 AM
thook's Avatar
Maybe not the question you asked, but it doesn't hurt to make suggestions, does it? Get whatever you can get, for sure, if it's to your most comfortable convenience and budget.
Old 06-10-2010, 10:20 AM
livehho's Avatar
convenience yes
budget not (this Castrol stuff is $15 a litre)
Old 06-10-2010, 10:24 AM
thook's Avatar
Wow. Fortunately you don't have to change the tranny oil that often...haha.
Old 01-21-2021, 01:57 PM
Skdmrks's Avatar
I have a 1994 Toyota 4×4 short box pickup with a 5 speed Manual transmission. I live in Edmonton Alberta so temperatures vary from -30 C in winter & +30 C in summer. Looking to see what everyone would recommend for Manual transmission oil. I have a friend that claims this is the best. Any thoughts ?
Old 01-21-2021, 04:59 PM
Melrose 4r's Avatar
Canadian to American translator says that means: -22*F to 86*F 😁
Old 01-21-2021, 05:02 PM
outdoorjunky's Avatar
Napa can order you Royal Purple or Redline MT90. I like the MT90 for my w56.
Old 01-21-2021, 05:10 PM
JJ'89's Avatar
GL-4 SAE 75W-90
Answering your specific questions, the short of it and the long of it: Yes. No, not where you live.
Old 01-21-2021, 07:11 PM
Blueman's Avatar
All my older manual transmissions get MT90 these days, but Redline GL-5 75W90 in the transfer case.
Old 01-23-2021, 04:20 AM
muddpigg's Avatar
If it’s “yellow metal safe”. You’ll be fine. Seems most gear oils at parts store aren’t in my experience. Will shave life of your tranny.
89fourrunner
10-27-2017 02:06 PM
goodenough
05-20-2017 08:07 PM
RustBucket
05-25-2014 06:39 PM
bugdude
04-03-2005 12:19 PM
jimber00
10-02-2003 06:42 AM
Quick Reply: Manual Transmission Oil for 22RE
