YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-24-2008, 09:23 AM   #1 (permalink)
impalla350's Avatar
Send a message via AIM to impalla350 Send a message via Yahoo to impalla350
Losing Clutch Fluid
I have a 87' 4Runner with a 22-re and was an automatic from factory but was converted to a 5 speed, the problem is i was going down the road yesterday and all of the sudden i couldnt get the truck in gear, and the clutch pedal had no tension , i got to a friends house and checked the clutch fluid and it was empty, i filled it and pumped the clutch and it works fine now... i looked at the slave and clutch master cylinder and no leaks, also checked the lines... any suggestions ?
__________________
1987 4 Runner , 22RE
2004 YZF600R
impalla350 is offline
Sponsored Links
To remove this ad, register today!
Old 07-24-2008, 09:26 AM   #2 (permalink)
iamsuperbleeder's Avatar
Send a message via Yahoo to iamsuperbleeder
you've got to have a leak somewhere... clutch fluid doesn't just run out...
__________________
91 Pickup, 4wd, 22re, stock suspention, rollin on 31s... for now that is...
287 thousand miles and counting...
Linkies:
YotaTech photos
MySpace
Quoties:
Quote:
Originally Posted by DeathCougar View Post
Take the oil cap off and throw it away, you dont need that. May as well drain the oil, dont really need that either. Just extra weight, and without that extra weight, you'll gain like, 400 horsepower!
Quote:
Originally Posted by toomanytoyotas View Post
4 tires in the air is o.k., so long as they are closer to the ground than your roof is...
iamsuperbleeder is online now
Old 07-24-2008, 09:28 AM   #3 (permalink)
impalla350's Avatar
Thats what i figured... but the slave and master cylinder are dry... i am guessing that when i bought the truck it was low, or possibly had air in it, alot of air... ive only had the truck 4 weeks now... should i try to bleed the hell out of it and if that doesnt work just replace the slave ?
__________________
2004 YZF600R
Old 07-24-2008, 09:33 AM   #4 (permalink)
That sounds like a good idea. Bleed them, make sure every connection is tight and dry, and if you still losing fluid, it's more than likey the slave; for some reason they tend to go first. If you've got the extra cash on you though, replace the master with it, cuz it's probably not far behind.
__________________
Linkies:
YotaTech photos
MySpace
Quoties:
Old 07-24-2008, 09:36 AM   #5 (permalink)
impalla350's Avatar
Thanks man, i figured when i checked the clutch fluid and it was empty then refilled it, it got air in it so im sure it has some in it now... i will bleed it in a bit and let ya know what happened...
__________________
2004 YZF600R
Old 07-24-2008, 09:47 AM   #6 (permalink)
Zombie's Avatar
Check inside the cab at the firewall. Mine is leaking there, it drips and is absorbed into the carpet. Just found that on mine last week. Anyone know if it can be rebuilt or a just a seal replaced? I can probably get my hands on a used clutch m/c if needed.
__________________
"87 rust free Texas 4Runner, 2" body lift, 33" tires, extra springs in the rear, 4:10 gears, 22re and no gas mileage.
Zombie is offline
Old 07-24-2008, 03:23 PM   #7 (permalink)
toyminator2000's Avatar
Quote:
x2. Mine leaked inside on to the carpet too. Don't know if you can get a rebuild kit or not. I just bought new from Toyota.
__________________
1989 Pickup- 255,xxx miles, SAS, 5.29 v6 Detroit rear, FJ80 ARB Front, Bobbed bed, 95 4Runner front clip, 37" Swampers
1999 4Runner SR5 Sport Editon
1988 4Runner SR5 Blown up 3.slow
1992 Lexus SC400
toyminator2000 is offline
Old 07-24-2008, 10:43 PM   #8 (permalink)
never thought of that, probably cuz i never had one do that to me... good point guys!
__________________
Linkies:
YotaTech photos
MySpace
Quoties:
Old 07-25-2008, 01:28 PM   #9 (permalink)
impalla350's Avatar
HAH! I checked the firewall/floorboard and its leaking there, the carpet is soaked in brake fluid, its leaking at around the piston seal- replacing the master cylinder tomorrow thanks guys
__________________
2004 YZF600R
Old 07-30-2008, 10:00 AM   #10 (permalink)
impalla350's Avatar
Installed a new clutch master cylinder and everything is fine, it took me awhile to bleed the system, but it works great now...
__________________
2004 YZF600R
Old 07-30-2008, 11:32 AM   #11 (permalink)
mYnAmEiSmUd's Avatar
Send a message via AIM to mYnAmEiSmUd Send a message via MSN to mYnAmEiSmUd
I currently have the same issue. Master leaking on interior of firewall.
For the record, Partsamerica.com sells rebuild kits for both the master and the slave.
I think i will just buy them off of MC. OEM toyota.
__________________
1988 4Runner
22RE 5 spd
truckdomain
mYnAmEiSmUd is offline
Old 07-30-2008, 11:39 AM   #12 (permalink)
scuba's Avatar
Quote:
Quote:
uno. very good point.
Dos. you beat me to it
__________________
{1991 4x4 p/u 22re--elbow mod}
{Wrecked 86 one ton.}
Both under construction :)
Dad- 1999 4runner base 2x4, 2.7, 5speed, 49k, cherry.
Quote:
Originally Posted by Junkers88 View Post
That and I don't want Marlin to send me a Jeep pamphlet as an incentive towards my next buy as a joke. I'll bet he has that kind of sense of humor.
scuba is offline
Old 07-30-2008, 11:42 AM   #13 (permalink)
impalla350's Avatar
Yeah, well i checked Autozone and they had the Master Cylinder NEW not a rebuild with a lifetime warranty for $27.99,and it came with the reservoir and a little rubber floater to show the level- so i couldnt beat that...they also have the slave cyl. NEW for $13.99 with a lifetime warranty....
__________________
2004 YZF600R
Old 07-30-2008, 11:59 AM   #14 (permalink)
Quote:
I had and 81 pickup.. leaked in the cab, put a new kit in worked great.
Recently in my 004runner master went, no leaking but jut no pedal. Replaced the slave first then the master.. I was told to check under the boot of the slave, sometimes the fluid just accumulates there.
I agree.. bleed it first.
tommytuttle is offline
Old 07-30-2008, 12:15 PM   #15 (permalink)
scuba's Avatar
well if you happen to get a new master and slave, make sure you bench bleed first
__________________
scuba is offline
Old 07-30-2008, 01:06 PM   #16 (permalink)
kramykram's Avatar
^^^^ Whut he said. Buy a new one and don't bother with a used unless you plan on rebuilding it yourself.
__________________
89 T4R 22RE 31 x 10.5
198,000 and still kickin!!!
And I can't keep stupid people off her ass!!!!
Quote:
Originally Posted by SwampThing View Post
You got enough astroglide and you can fit anything anywhere.
kramykram is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Leaking clutch fluid G's 84 Runner 84-85 Trucks & 4Runners 2 07-13-2007 05:50 AM
Clutch leak/Dark clutch fluid geoduke 86-95 Trucks & 4Runners 2 04-04-2006 06:51 PM
97 runner - clutch fluid replacement? denverbikeguy 95.5-2004 Tacomas & 96-2002 4Runners 4 07-15-2004 07:40 PM
Clutch fluid ?'s CMD93 95.5-2004 Tacomas & 96-2002 4Runners 4 03-15-2004 02:18 PM
Clutch fluid... rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 5 08-21-2003 07:26 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.1.0
2002-2008 Yotatech.com
