Looking for a torque spec
Old 10-05-2013, 06:30 PM
Daenerysdad's Avatar
Just finished swapping out the control arm bushings on my '93 4x4 in preparation for the Blazeland long travel. Looked all over the internets, even went to my colleges auto tech shop looking for the upper control arm cross shaft nut torque. They are 27mm nuts with The "crush it on the corner of the threads" ones. All I've been able to find is the "wrench it on good and tight" type torque numbers. Anybody know a little more specific number?
Old 10-05-2013, 09:21 PM
BlazeN8's Avatar
I have not come across the spec for this assembly. The cross shaft and companion flange nut are 18mm x 1.5 not 27mm? I use a 1-1/16" socket on the nut (maybe this is 27mm socket/wrench?) Here is a link for some torque specs for 18mm bolts http://www.dansmc.com/torque_chart.htm As you can see its dependent on the grade of the bolt. For low grade, the spec is 60-130 lb/ft for Grade 8.8 its 201 lb/ft. I suspect the cast steel cross shaft is less than Grade 8.
When I re-assemble after the rebuild I estimate a torque spec of 75-100 ft/lb. I also use a blue thread lock compound and stake the companion flange nut. When you perform a poly bushing conversion the bushing is free floating and non-binding. This means the bushing is free to rotate on the inner steel sleeve or outer steel shell (unlike the factory rubber bushing that twist the rubber bonded to the inner steel sleeve and outer steel shell) so it doesn't need to be as tight. The nut is locking the inner steel sleeve to the cross shaft. Hope that helps, and gives you some peace of mind.
Old 10-06-2013, 09:40 AM
MudHippy's Avatar
166 ft-lbf
http://personal.utulsa.edu/~nathan-b...27frontsus.pdf
1-1/16" = 26.9875mm
Old 10-06-2013, 02:24 PM
Originally Posted by MudHippy
Ahhh! That's awesome! Everything indeed in one handy document, all at the tip of my fingers!
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
Dale Johnston
11
10-31-2015 10:22 PM
Kamaloha
10-16-2015 05:13 PM
Obmi
10-04-2015 11:30 AM
Quick Reply: Looking for a torque spec
