Looking for an 88-92 3vze distributor plug wire diagram
Old 11-09-2013, 03:52 AM
bone collector's Avatar
in the plug of the 88-92 of the 3vze what is each of the wires? which one is ground and signal, hot, etc. I have the 93-95 wire diagram, just need the 88-92. trying to help a friend out. I cant seem to find it on bing or google.
Old 11-09-2013, 06:14 AM
wyoming9's Avatar
Red face
Just what year? 4 runner/ truck??
Big difference between 88 and 92.
just what are you trying to figure out Since the harness runs to the ECU
Old 11-09-2013, 06:21 AM
im trying to test a 90 3vze distributor per the fsm. I have the 93 fsm test for the distributor. the 93-95 distributor plug is different than the 88-92 plug. im trying to figure out what wires to test. in what order etc etc.
the 93-95 plug is a single row of 4 wires
the 88-92 plug is a double row of 2 wires.
hence my confusion
Old 11-09-2013, 08:00 AM
guzzirik's Avatar
are the colors the same? IE 1991 white red
yellow green
Old 11-09-2013, 08:07 AM
94 wires are white red black and green
Old 11-09-2013, 08:21 AM
guzzirik's Avatar
I read you were trying to test a '90
Old 11-09-2013, 08:26 AM
Yes I am. They FSM I have covers the 93-95 distributors. The wire colors do not match up or the plug configuration. I'm am looking for the correct testing procedure and wire color designation
Old 11-09-2013, 08:30 AM
guzzirik's Avatar
OK. As soon as I can find my fsm I'll take a pic of the diag and post. Be advised, Iv'e cleaned up and have no idea where it is....
Old 11-09-2013, 08:42 AM
guzzirik's Avatar
What is the problem so I can delineate?
Old 11-09-2013, 08:53 AM
guzzirik's Avatar
Found it...Is this what you want?http://DSCN0022.JPG
Old 11-09-2013, 08:54 AM
guzzirik's Avatar
How do you attach a file???
Old 11-09-2013, 08:55 AM
https://www.yotatech.com/forums/f116...e-12-a-274839/
I was trying to help this guy out. I then realized that I didn't have the correct information for his truck. thanks for the info
Old 11-09-2013, 08:59 AM
to attach a file you need to push the "go advanced" along the top is a button to add attachment
Old 11-09-2013, 09:10 AM
guzzirik's Avatar
try this...looking at the dist plug up left G1...up rt NE.....Low left G2...Low rt G neg
Test...G to G neg...205 to 255 ohm
test...G2 to G neg...205 to 255 ohm
test...NE to G neg...205 to 255 ohm
if not, replace dist housing.. hope this helps
guzzirik's Avatar
thanks for the go advanced thing...
Old 11-09-2013, 09:53 AM
answer me this:
what color are the wires for :
G
G-
G2
NE
that would help a lot
Old 11-09-2013, 10:19 AM
guzzirik's Avatar
G...red G-...yellow G2...green NE...white
Old 11-09-2013, 10:23 AM
sweet thanks
Old 11-09-2013, 12:50 PM
MudHippy's Avatar
I believe you may be wrong there. From what I've gathered the wire colors should be as follows.
NE
G1
G-
G2
BTW, bc...I answered this question in a previous thread that you were also involved in.
https://www.yotatech.com/forums/f116.../#post52042937
EDIT: All posts will be corrected for total accuracy. Sorry for the confusion.
Old 11-09-2013, 02:07 PM
guzzirik's Avatar
Well, I have unplugged the connector and staring at it as it heads out towards the dist, I have; G1 red NE white G2 green G- yellow
Quick Reply: Looking for an 88-92 3vze distributor plug wire diagram
