lockrite problem "clunking" "jerking" jerking need advice
Old 10-03-2010, 05:41 PM
drkblu4runner's Avatar
Exclamation lockrite problem "clunking" "jerking" jerking need advice
ok i got a problem!!
installed it and drove detroit ez locker and drove up to Tahoe about 120mi round trip all highway. first, every few secs it would Bang then jerk me left or right. but the big problem is a few times a min it would BANG rev up, sometimes times 200rpm and jerk the truck BBBAD. is that normal, to me its un drivable and is going to brake something else, only does that over about 25mpg. im going to take it out if thats normal.
i have never been in a truck with a lockrite so i have no idea whats normal.
bolth tires spin in dirt now and unlock in parkinglots
i know this is NOT it but, felt like i sucked a bolt through the ring pinion.
the lockrite Manufacturer Part Number: 813a028
got off ebay!
even came with extra parts.... 9pins, 7 springs, few extra spring caps
i think i set the springs and pins up right. (ill post a paing shot pic)
thanks for the help yotatech
Old 10-03-2010, 05:49 PM
Old 10-03-2010, 06:45 PM
[IMG][/IMG]
this is a stock photo from summitracing.com
see how there is 4 green circled spring ends, well i used 8, one on each ond of spring
im thinking there is too much tension, i have no clue if thats it tho. any one have any ideas?
Old 10-03-2010, 09:16 PM
they came with no instructions
Old 10-03-2010, 09:55 PM
RMA
RMA's Avatar
i have a lockright and mine doesnt do that ..
i installed mine a while ago and honestly dont remember how it all went together .
try this site there is lots of pics .
http://www.gearinstalls.com/
The following users liked this post:
drkblu4runner (11-20-2010)
Old 10-03-2010, 10:01 PM
muddpigg's Avatar
Check your tire pressure. Sounds too simple but mine would act similar when one tire was lower than the other.
Old 10-03-2010, 10:52 PM
ya i looked at all of zuk's installs but the spring and pins are different. i will check tire psi tho
Old 10-04-2010, 05:23 AM
muddpigg's Avatar
If the tires check out. Did you check the carrier tolerances when you installed?
Old 10-04-2010, 06:05 AM
1styota4X4's Avatar
my have frt and rear lock rights in my 85 and every now and again after i go around a turn it it will pop (im assuming going back to normal position). What your describing seems like they are to tight.
Old 10-04-2010, 09:19 AM
ya about ten thousandths. it it may be too tight because of the extra mm of tension on all 4 springs, idk. i think im going to have to take it all apart again tho
Old 10-04-2010, 12:31 PM
i definitely am NOT suppose to use that extra spring cap look here
https://www.yotatech.com/forums/f116...locker-105471/
im just hoping thats it but idk
Old 10-05-2010, 09:21 PM
going to take the 3rd out again and take those spring caps out and hope thats it. any one have any input?
Old 10-05-2010, 10:38 PM
tires are almost new and with same psi
Old 10-05-2010, 11:54 PM
does this look normal, there is about 1mm difference
Old 10-05-2010, 11:56 PM
those are for the front. should i bother installing them?
Old 10-06-2010, 02:05 AM
Foglifter's Avatar
Doesn't look right at all. Can you send it back for replacement?
Also, Ive never had issues with unequal tire pressure. The lockrite reacts to tire slip.
Unfortunately it sounds like you need to pull the third again and check your assembly.
Old 10-06-2010, 06:07 PM
took it all apart today and took out the spring cap. it didnt help. going to have to take it all apart again and put the spider gears back in
Old 10-06-2010, 06:19 PM
Foglifter's Avatar
Might give Richmond a call. If anything they can send you an instruction sheet. I know it's a PITA, hang in there.
(864)843-9275
Old 11-02-2010, 08:34 PM
put powertrac in and it works GREAT. cant even tell its back there. going to try the ezlocker in the front tho. hope its ok.
Old 11-02-2010, 10:15 PM
muddpigg's Avatar
So what was the verdict with the locrite? Did you buy it used?
Quick Reply: lockrite problem "clunking" "jerking" jerking need advice
