knock sensor/pigtail/ 95 3.o
mine is a 95 4runner, newly rebuilt 3.0 / auto.
i get code #52. knock sensor code. engine loses power. cel comes on.
does anyone know where to get a new pigtail?
also, how about the pigtails connections?
one wire(black,blueshield) goes to the knock sensor, the other wire(brown) is taped to the shielded sensor wire.
where does the brown wire go?
please help!!!!!!!
please help!!!!!!!
knock sensor issues/95 3.0
i did check with toyota parts, said i had to buy a new wiring harness.
where can i find just the knock sensor pigtail?
the other is the ground, the ground is actually the sensor itself, being as it screws into the block.... as for the pigtail, just go to toyota, I think I paid $14 from my local dealer.
The dealer sells the pigtail, just give them a call.
It is a bear to replace, given that it is under the intake manifold. When it was rebuilt, did the knock sensor get replaced? Most likely not, as if someone did the sensor they would have known to do the pigtail.
Good luck
Good luck
just ordered the pigtail from toyota, will be here thursday, cost me $20. plus 10 for shipping, i live out in the sticks.
(original sensor, & pigtail)
i cant wait to drive it, bought it last month, motor was in the back, in pieces.
new parts:
plugs, wires, cap, rotor, wpump, new idlers, heads rebuilt, manifolds cleaned and painted, tbelt, hoses, radiator, thermo., ect.
cost:
4runner: $650.00
parts: $1,200.00
title: $200.00
looking forward to driving it soon.
new parts:
cost:
4runner: $650.00
parts: $1,200.00
title: $200.00
Did you happen to have the distributor out during the rebuild?
My brother had code 52 problems with his 90 4Runner with the 3.0. We did an engine rebuild, put everything back together and it had NO power. It was throwing the 52 code so he replaced the pigtail, still nothing... Ended up being that the distributor was off by a tooth so the timing was way off.. Moral of the story, check your timing.. After we fixed up the timing it ran perfect.
Location: I live in Red Bluff ca. Right by the Sacramento river
Where does the knock sensor connect on the truck side? Previous owner bypassed the sensor but we replaced it, where does it lead to on the truck side? Not the side under the manifold.
some drunk guy
08-03-2021 06:09 PM
