Keyfob
Old 10-28-2006, 04:57 PM
Phate's Avatar
Keyfob
I have a 90 4runner with a factory or dealer installed alarm and I was hopeing someone could give me instruction on how to progam a new key fob for it.
Old 10-28-2006, 05:33 PM
HAVOC's Avatar
I can't find any info on a factory installed alarm (keyless entry) on a 90 4Runner.
Might be an aftermarket alarm.
Old 10-28-2006, 05:42 PM
Phate's Avatar
it is from toyota security, the origional keyfob says toyota, the valet button says toyota, the brain is under the factory carpet under the drivers seat, when it goes off it honks the factory horn the dealer will program it for 100 bux, and id rather not pay them.
Old 10-29-2006, 12:54 AM
Phate's Avatar
Found it
its a TVSS (Toyota Vehicle Security System) ,Locate a small hole in the ECU, turn the key on to run, engine off and push the button in till the status monitor goes steady on, within 4 seconds, push the button on the transmitter, the horn will sound when it has acknowledged it. PS, newer RS 3000 transitters will replace the TVSS ones and are much more durable. ;-)
On my truck this TVSS ECU was located on the passanger side behind the glovebox.
http://groups.google.com/group/alt.a...cbdac998a8192e
Old 10-29-2006, 01:40 AM
HAVOC's Avatar
Oh' the LX450 has it under the drivers seat also. I could have looked at my Lexus info for that. But it's good you found it.
Old 10-29-2006, 07:42 AM
Phate's Avatar
cool. > not sure what the heck that is under my carpet, probably a relay box or something (have to have the seat out one of these days just to take a look.)
Old 12-08-2009, 03:50 PM
gTgarrett's Avatar
this was really helpful thanks
Old 10-31-2010, 01:17 PM
cory8926's Avatar
took me long enough find this post... I must be out of the loop but this is the first I've heard of key "fob"
So easy worked perfect!
jwmckin
11
09-30-2019 09:20 AM
kapeket
08-23-2015 12:51 PM
Quick Reply: Keyfob
