Intermittent idle surge when warming up when brake is pressed
Old 02-27-2008, 07:24 PM
91Toyota's Avatar
O.K, noticed this about 2 weeks ago. When my truck is cold and running when I push the brakes the idle does not surge. But, when my truck is fully warmed up it does not do it either. But, when my truck is partially warmed and the brake is pressed the idle will start to surge 500 rpm (of course while in N or when the clutch is pushed in) I heard my idle could be too far up? (Idles at 1100) and something about my coolant becoming a certain temp and the sensor on the bottom of the butterfly assembly read the warmth of the coolant and then changes the idle...is it that thing?
Thanks
Old 02-27-2008, 08:12 PM
mtnfreak's Avatar
Yea. Probably either the idle set too high or you've got an air/vacuum leak. Have you changed anything lately? Any known cracked hoses?
Old 02-27-2008, 08:42 PM
91Toyota's Avatar
I took off my head for fun! And it has 40psi in the #3 cylinder...but starts better than my brothers truck with a 22re too.
Old 02-27-2008, 09:12 PM
hardieca's Avatar
Sounds like Idle set too high
Old 02-28-2008, 06:35 AM
91Toyota's Avatar
Thanks...I'll turn it down and I'll see if it makes a difference.
smthwsn357
05-01-2024 07:28 AM
Sleaker
08-26-2020 06:03 AM
montanatruck
02-26-2017 07:07 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Intermittent idle surge when warming up when brake is pressed
