Old 03-30-2016, 10:57 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Lighting Guides
Print Wikipost
interior dome light problem
Old 04-08-2020, 03:14 PM
acisne's Avatar
wire connection
Originally Posted by RobD
Put a meter on it. Check the socket for power. My guess is your door pin switch has bitten the dust.
Hi RobDn,I noticed the power wire is dead, I would like to know where it is connected to fix it.
Itried to found the diagram but i was able to find it
Old 04-08-2020, 04:49 PM
scope103's Avatar
The "power wire"? What's that? (for that matter, what does "dead" mean?)
Let's assume you were using a multimeter. Let's assume you removed the dome light bulb, and checked BOTH SIDES of the contacts to GROUND (not to each other). Let's assume you got zero volts to ground on each contact. In '93 on (at least, probably much farther back, but you didn't tell us what year you have) the dome light socket is connected to battery all the time, and it the switch connects it to ground to light it. The wire that should be battery voltage all the time is black (one of the few single-color wires) to the Integration Relay. That's where to look.
Old 04-11-2020, 02:52 PM
acisne's Avatar
interior dome light issue toyota pickup 1990 3vze
first of all thanks for the answer , i will try to be more specific, my truck is a toyota pickup 1990 v6 3vze. i removed all domes.
the first one with 1 mirror with 2 bulbs (it is not working)
and the second one ( it is working)
i checked voltage with multimeter the first dome conector (ground reference in one multimeter contact)
left side (red and white ) right side (red and green)
1 ​​​​scenario with dome number 2 connected (off position) and closed doors:
RW wire has 240mv
RG wire has 50mv
2 scenario with dome number 2 connected (off position) and open doors:
RW wire has 20mv
RG wire has 26mv
3 scenario with dome number 2 connected (on position) and closed doors:
RW wire has 200mv
RG wire has 230mv
4 scenario dome number 2 connected (on position) and open doors:
RW wire has 30.6mv
RG wire has -330mv
5 scenario dome number 2 connected (door position) and closed doors:
RW wire has 12.55v (battery voltage i supposed)
RG wire has -80mv
6 scenario dome number 2 connected (door position) and open doors:
RW wire has .905v (almost 1 volt :S)
RG wire has 30mv
i am really lost because i cant see electric diagram of both dome lights only one is shown into FSM
​​​​​any idea,help or blessing would be cool thanks in advance again.
06-01-2021 01:51 PM
Sleaker
08-26-2020 06:03 AM
rushw
07-18-2015 01:46 PM
msane99
07-11-2015 08:08 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: interior dome light problem
