Intake bolt pattern v6
Old 10-23-2011, 02:29 PM
buel09's Avatar
Does anyone have a intake diagram for the bolt pattern for the 3.0 v6 1991 toyota truck and the torque. thank you
Old 10-23-2011, 03:12 PM
xxxtreme22r's Avatar
Torque specs should be listed in the FSM. Free download search for it. Bolt diagram will be contained on the intake manifold gasket set. There is also a few 3.0 rebuild threads here you might wanna take a look at.
Old 10-24-2011, 05:12 PM
MudHippy's Avatar
13 ft-lbf, ALL the bolts and nuts for the throttle body, plenum chamber, and lower intake manifold(no specs for the VAFM nuts...gutentite!).
Why would you want the bolt pattern? What are you going to do with that? And which bolt pattern are you talking about anyway? The intake manifold to head pattern, the plenum chamber to intake manifold pattern, the throttle body to plenum chamber pattern, or the VAFM to air filter box pattern?
Blamalam
03-12-2022 07:34 AM
pplusent
09-18-2018 10:02 PM
Dakotaneu
08-15-2015 07:24 AM
Quick Reply: Intake bolt pattern v6
