intake air temp sensor
Old 10-03-2008, 02:51 PM
ontario4runner's Avatar
hey guys.
quick question, 91 4runner, 3VZE have searched but cant seem to find anything, as well in the manual i downloaded from the sticky
where on earth is the air intake temperature sensor? and how do i test it.. code 24 i believe.. as well whichever code for coolant temp sensor but i got that one covered.. please help! my search for my terrible idle is seemingly coming to an end! haha me---> toyota
Old 10-03-2008, 03:09 PM
anyone at all?
Old 10-03-2008, 03:10 PM
space-junk's Avatar
im not sure that there is an "air intake temp sensor"
Old 10-03-2008, 03:14 PM
really? because jumped te1 and e1 terminals and came up with code 23/ 24 which is intake air temperature sensor/ intake air temperature circuit
Old 10-03-2008, 03:23 PM
project91's Avatar
Intake air temp sensor is the little white probe sticking down into the AFM.It will be on the intake tube side,(have to pull the AFM off) measures the temp of the air that is coming through the AFM....can be cleaned with electrical contact cleaner...if the problem persists, more than likely the AFM is bad. The wires that connect to it go through the main plug that is connected to the top of your AFM.
Old 10-03-2008, 03:27 PM
AFM? air flow meter? maybe haha
Old 10-03-2008, 04:40 PM
space-junk's Avatar
I stand corrected... just chalk it up to being a noob!!
Old 10-03-2008, 04:55 PM
Jay351's Avatar
Use an ohm meter and test out your AFM. It takes all of 10 mins to do, if the air temp sensor is wired into it, you will be able to find out the problem.
Old 10-03-2008, 05:09 PM
jason191918's Avatar
http://www.ncttora.com/fsm/1993/engine/92volumeai.pdf
I never heard of a temp sensor, so it must be part of the AFM. Here is how to test it.
Old 10-03-2008, 05:23 PM
myyota's Avatar
The temp sensor is inside the AFM, if you remove the plastic cover you can get to it and were it plugs in.
Old 10-03-2008, 05:58 PM
haha its all good! at least you took the time to have a look see, as i said i cant find much on it myself so if it wasent for the code reading i wouldnt have realized it myself!
to everyone else thanks mucho any more info would help greatly
is afm air flow meter?
Old 10-03-2008, 06:08 PM
Jay351's Avatar
Yes, Volume Air Flow Meter.
Old 10-03-2008, 06:12 PM
awesome, thanks jay.. so the intake air temperature should be located inside of that? or should i be able to see the sensor with the AFM still on?.. i guess tomorow morning i will find out if i get lost ill post some pics
Old 10-03-2008, 06:25 PM
bigt's Avatar
not hard and with pics there aint nothing yotatech cant answer.. theres always some bored yota nut on here!
Old 01-27-2011, 03:53 PM
FireRox21's Avatar
Iat
I too am getting a code 24 for the IAT sensor. I just replaced the AFM, but I am still getting a check engine light/code. However, I pull up the replacement IAT sensor at Auto Zone and get a little message that says the sensor cannot be used on pollution controlled vehicles. What does that mean? I just passed smog here in California and won't be due for another 2 years. How am I supposed to change this sensor and get rid of the light/code, if I'm not supposed to use it on pollution controlled vehicles? Anyone have an idea, or is this some stupid California thing. BTW, I have a 1990 4Runner SR5 V6 with a new engine, new everything, new sensors (except the IAT), etc. Any help would be great!!!
Old 01-27-2011, 04:02 PM
4Crawler's Avatar
You can test the sensor:
- http://www.4crawler.com/4x4/CheapTri...tml#AFMtesting
Then see if that AFM signal is getting back to the ECU by testing the ECU connector pins for that same signal:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
Old 09-07-2014, 01:20 PM
JoelNZ's Avatar
Hey guys, my IAT is now playing up as well - short of replacing the whole afm what aftermarket IAT sensor can I use? OEM part is $220!
I did think of replacing it with a 7MGE upgrade...
Old 06-19-2015, 05:03 PM
Dam3vze's Avatar
Intake air temp
The iac is the air intake temp sensor I believe and it is located in the throttle body!
Old 08-23-2015, 04:51 PM
nilow11's Avatar
codes 24 and 31
my 93 Toyota pickup turns over but wont start up I jumped the te1 and e1 to get the codes. the truck is throwing codes 24 and 31. Since I started driving the truck it did it 3 different occasions and it was always random. Can the air flow meter really cause the truck to not start up? I can also spray starter fluid in the intake and it will start up off of starter fluid then die again. can anyone help me?
Old 08-23-2015, 05:56 PM
4Crawler's Avatar
You bet, air flow meter also has the fuel pump contacts that keep the fuel pump running on the EFI engine:
Might try the fuel pump test jumper as it should be running while the starter is running:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Quick Reply: intake air temp sensor
