instantly losing total fuel pressure in rail
Since there's a check valve on the fuel pump, if it's leaking down faster than specs, then your cold start injector may well be leaking into the throttle body. You can pull it off the TB without taking the fuel line off. Put a catch container under it, pull the electric cable off of it, and turn the fuel pump on with the test jumper. You'll easily be able to see if it leaks with pressure on it.
Don't forget though, it could be any one of the injectors.
Let us know what you find
Pat☺
Pat☺
The following users liked this post:
Dernation (04-25-2021)
the leak and second the air being introduced.
the loss of pressure when not running isn't really a problem since a properly working fuel pump can repressurize a static fluid very quickly. So, a small pressure leak in a closed system isn't that big a problem. The fact that when the gasoline moves toward gravity it creates a vacuum above it and stops the loss (think of your finger on a straw you pull out of a drink). The fact that the fuel rail is empty means that the system has a leak large enough for passive air to be pulled in which allows the fuel to drain. If an injector is not fully closing it will allow air in and the system to drain. A hole in your fuel line will also allow air in, and since your smart enough to post on yotatech I'll assume you're smart enough to check for fuel leaks outside the vehicle. That said, check the fuel line inside the tank after the pump. It may have a hole that sprays inside the tank so you never see.
Remember, a pressure loss is corrected by a properly working pump in around 3 seconds in my experience. So not a quick start but an "easy" one. Recovering from air in the system from a leak large enough to drain the fuel rail takes longer since the air has to be evacuated.
Pat☺
Pat☺
Hydraulic pressure can be lost very quickly because fluid doesn't stay compressed well because of its expansion. However, you're saying the fuel rail is going empty; this indicates 2 things. First
#25
When I've emptied the fuel rail (filling it with air) for maintenance (replacing the head gasket), I "bled" the air out by running the fuel pump with the FP connector. It took less than 3 seconds for all the air to get pushed out (you can hear the air going through the FPR). Pressurizing a zero-pressure fuel rail takes much less time.
I really doubt Yotainmyblood's long-start problem has anything to do with fuel rail leak-down. I think he'd have more luck looking elsewhere.
old87yota (04-26-2021)
#26
Given all that you've replaced so far, my guess would be the CSI allowing air in when the fuel pump is inactive. Yes, it's a guess, but I think an educated guess. I would still test it to be sure. If it's allowing air to bleed in, it will bleed fuel out when it's pressurized. Can't hurt to certain. That could also let you know that you might need to check the entire fuel system, back to front, for a small little leak when pressurized, if the CSI checks good.
Don't forget, even a remanned injector could have the leakage problem, too. Again, something to take a look at if the CSI checks good.
Having said all that, I still suspect the CSI. Just me, though. A leaking CSI would cause a rich running condition, so you might be able to tell from that, but I'd pull it off to look at it, as I specified. It might be such a small leak that it doesn't affect the way it runs very much.
Just me, though.
Good fortune to you!
Pat☺
Just me, though.
Pat☺
#27
I really don't see how Yotainmyblood could determine that the fuel rail is "full of air." Crack a banjo bolt, nothing comes out. That does not tell you there is any air in the fuel rail; it only tells you there is no pressure. (Which is exactly what you would expect after sitting overnight.) For any appreciable amount of air to be introduced, you'd need a very large hole near the highest point of the fuel system. (The fuel tank is never under negative pressure because of the vented fuel cap, so you're only talking less than ~0.5 psi from 12-18" of "head" of gasoline.) As soon as the fuel pump starts and raises the pressure to 50psi or so, that hole is going to be spraying a lot of fuel. If it's a fuel line leak, there will be a big puddle under the truck. If internal (any of the injectors), the engine will flood out (and maybe hydrolock), and would never run no matter how long it was cranked.
Yup.
Yup.
, it would save people from having to repeat what they have already said and done. I know what my long first start problem is. When there is no fuel in the rail until the fuel pump comes on and puts fuel in it, it will take UT a while to start. And as I have stated before, I can put the jumper in and turn the key and let the fuel pump run for about 10 seconds and then it will start right up.
#28
Just me, though.
Pat☺
Just me, though.
Pat☺
#29
Yup.
Yup.
#30
I just pulled the CSI and put in the jumper and it doesn't leak out any fuel. At least after ten minutes whit the pump running. I was hoping that was going to be the problem but it don't seem like it is. I guess I'll end up shortening the metal line on the pump hanger and splicing in a one way check valve between it and the pump. Since most of the line is metal except for the 6" of line on the top of the tank and the foot of line where it comes up from the frame to the motor. Those lines have the fittings but there isn't a check valve that has the 14mm ends where it will screw right in. So I'll have to get one that just clamps on to rubber lines. It just bugs me that there is something wrong and I can't find it. Unless every fuel pump I got has a bad check valve, and I don't think that's it cause I pulled the one off my other truck and it don't have this problem. There are 6 injectors and it just takes one bad one, but I got new ones and just to be sure, I sent off the ones I pulled and they said that they didn't leak or stick. So unless they lied and I got a bad one in my bunch, then that's not it. And if it is.... and not knowing...i mean, where do you stop? I'm saying here. I've spent all I'm going to and I know how to fix the problem, but it just bugs me.
#31
Pat☺
Pat☺
#33
I pulled the small line that comes from the back of the motor on that little bimetal valve, and it was dry, but I don't see how that would effect pressure in my sending line since its not between the fuel rail and the fuel pump? I know I would effect pressure in the tank but that shouldn't cause my problem. There's only 3 things that can be wrong with the problem I have. At least from what I know... Leaking check valve......leaking injector..... Leaking line.. Even a very slow leak. I just got to find which one. I'm going to pull the fuel rail and leave the injectors on and put the jumper in and pressurize it and hope the injectors don't fly off and let it set to see if one is leaking. They are new but that's where the leak has to be. Unless the line is leaking somehow that I can't see and it's not letting fuel out when I got it running? But I don't see that happening. One person suggested trash in the fuel causing check valve to stay open? I've checked the fuel and it was clean, plus it should blow out a piece of trash out of that little plunger when it comes on .. I could see that happening maybe once in awhile, but not everytime I shut it down. Frustrating!!
#34
Are you telling me that there should be no fuel pressure in the fuel rail after sitting over night? To be honest, I am not for sure what the service manual says but, I have two more of these 3.0 motors and both of them can sit for a week without being started and I can crack that same banjo bolt on them and there is enough pressure that fuel will spray out. I not saying a certain amount of pressure I'm just saying there's enough to make it spray out. And on this truck , I can crack that same bolt after it sits over night and no fuel comes out. That's why I'm saying there is no fuel pressure in the rail. Now if I start it up and shut it down , I can come back in about 5 hours and crack the bolt and fuel will spray out. I realize it looses pressure after a little bit, but it shouldn't lose all of it. And if it's supposed to , then it's different than the other two I got in my yard and different than any of them I have worked on.
Gasoline, like water, is essentially incompressible. To remove all 44psi from the closed fuel system would only require a few drops of fuel to leak back through the fuel pump check valve, or from one of your 7 injectors. I'm not sure you could even see fuel leaking through an injector at 3 drops per hour. So looking at your injectors (with what you know now) is not likely to be useful. Replace the fuel pump again? Remember that Denso is concerned about meeting whatever spec the manufacturer (Toyota) requires, which is only "stay above 21psi for 5 minutes." I don't doubt Denso tries to get their check valves to work "perfectly," but I also don't doubt they go ahead and ship with a leak that will drain all pressure in 8 hours. So your brand-new pump could be, for all you know, the source of your leak down. But you don't care; that's not the cause of your long-crank.
With what you've told us, I can't rule out the possibility that you have a fuel restriction, that is keeping your fuel pump from bringing up the rail pressure quickly enough. Or that the STArt circuit in the COR is not working. A fuel pressure gauge would answer those questions.
Last, do you think you might be acting a little too "prickly" when we're all trying our best to help you?
#35
No gas OR air in the fuel rail? Well, then what is in it? Hard Vacuum? We don't expect perfection in posts here, but you shouldn't get worked up when we just can't understand what you're asking.
Sigh ... I'm not suggesting that there is supposed to be no fuel pressure after over-night. All I'm saying is that is within spec. The actual spec is that it "shouldn't" drop more than 23psi (from 44 to 21psi) in 5 minutes. If it's okay to drop that far in 5 minutes, I would expect it to drop the remaining 21 psi in no more than another 8 hours. If you have one or two Toyota trucks that held a pound or two of pressure over-night, that's great. But Toyota doesn't expect that. Toyota expects that your truck, just like mine, will start right up with no pressure in the rail.
#36
while you have your fuel rail off, why don't you pull the pump , drain the system, and pump dyed gasoline in to help you. I understand that not having a banjo bolt leak indicates NO PRESSURE, but it does not indicate an empty rail.
while you have the throttle body easily accessible why don't you check that your throttle position sensor is functioning properly, properly adjusted, and not loose.
I understand why you feel like no one read your posts before posting a reply, but please understand that several of us have experience dealing with people who say they have done something and yet the method they used wasn't good enough. Example, you said you check the fuel lines. As the person who spent 7 years training mechanics end engineers how to care for the robots that build cars in Georgia, I understand that you THINK that was a good enough way to tell us that you checked ALL of the associated fuel lines and did so in a way that would catch any potential leaks, but I don't know you FROM ADAM and I'm 99.9% sure you didn't x-ray all of the lines or remove then fill them with 500⁰ steam then cap them then place them in a vacuum chamber and watch it under a FLIR camera. For all I know you looked at it with the vehicle off and the system depressurized. And your looking for a leaking fluid that evaporates.
AGAIN, I don't know you or your ability to properly check anything, so take what is said to you with a grain of salt because I've trained (alphabet soup) certified mechanics, and degreed engineers, all with years of experience and seen them make rookie mistakes. Heck, this website is full of examples of experienced people asking questions and getting told that a rookie mistake that they overlooked solved the problem.
YOU may be God's Gift to the wrench, but a knowledgeable person will accept ALL advice in GOOD grace, throw out what they don't need, and rephrase to get the information desired. If the same thing keeps getting said to you by different people with experience, THERE IS A REASON. Maybe it's how you worded something, or maybe it's something you didn't actually fully understand, but there is a reason.
Heck, take what I say with a grain of salt because before this year, I'd no meaningful experience in anything older than 2000.
I pray you have success, but you appear to be fixated on only one avenue of possible repair.
#37
Yes, the return line should just flow freely into to the tank. The regulator just controls how much fuel "leaks" back.
Since blocking the return line keeps the pressure up, it isn't being lost back through the pump. I know it's been replaced multiple times, but it really sounds like the regulator to me.
A bad evap canister can cause a long start because it can throw your air to fuel ratio off.
Oh , and if that's what it takes to truly check a fuel line then to be honest if I was to pull of the fuel lines I would have just bent new ones and replaced them. I've done that a couple times. And it's not a bad job. I do have special service tools but not to that extent.So you were absolutely right.
Dernation (04-27-2021)
#38
Well said sir. And the way I checked my lines was nothing to the sort of how you explained. But as an average mech. My thought was to pressurize them by having the truck running and then go over every inch and look for fuel. I'm definitely not gods gift to a wrench, ( maybe to a wrench) but I do have quite a bit of experience and common sense. Long story short... I found my leak and it was one of my new injectors .
CONGRATULATIONS!
So I can add the information to my tool box... which injector was it, how bad was the leak, did the oil smell of gasoline at all, any other potentially useful tidbits?
#40
It was drivers side, 2nd one back or middle one. Couldn't hear anything because of the fuel going through the FPR . plus mine didn't leak bad enough to make a leaking sound. I had to pull or loosen the rail enough to put a small cap under the injector and then hooked up the jumper and let the system pressurize, then unhooked the jumper and let it sit over night. I wrapped tape around each injector and rail so that it hopefully wouldn't blow off. I used big plastic bottle caps and put one under each injector cause I knew that it was going to have to sit overnight but did them all at once instead of doing one at a time and taking 6 nights. But came back next morning and found one cap full of gas. Didn't ever smell gas in the oil even though it probably leaked down 20 times. Couldn't tell anything by the spark plugs because I had just replaced them and due to blown head gaskets I had cleaned the tops of the piston when I replaced the head gaskets, so looking at the tops of my piston didn't do me any good. I replaced the bad new injector with one of my old ones and ran the truck. Went out this morning and first thing I did was loosened the same banjo bolt and fuel started to leak out, so I tightened it up and turned the key and after the normal 2 seconds it fired up. So I'm calling it fixed.
