Inertia Switch?
Old 03-14-2007, 07:36 PM
Barker87's Avatar
Inertia Switch?
Does andybody know where the inertia switch for the fuel pump is on a 1995 4runner( 3.0 automatic)?
Old 03-14-2007, 07:49 PM
keithguts's Avatar
I have the same rig, and would like to no more about this.
Old 03-14-2007, 07:56 PM
Barker87's Avatar
About the inertia switch?
Old 03-14-2007, 08:00 PM
keithguts's Avatar
ya, the switch
Old 03-14-2007, 08:06 PM
chadbobb's Avatar
what is an inertia switch?
Old 03-14-2007, 08:20 PM
Barker87's Avatar
It's a switch that activitates after you are in a collision and it shuts off your fuel pump so that your vehicle doesnt explode
Old 03-14-2007, 08:36 PM
^VooDoo^'s Avatar
3vz and 22re dont have them.
They used a fuse that just covers the power needs of the system, Anymore of a spike and it pops the fuse.
Also the AFM is the only other safety device, It shuts the fuelpump off if the engine dies.
(If you flip over the fuel pickup will cavatate and kill the engine but Ive wonder what happens if you just land on the side with a full tank, Theres nothing to stop the engine till it oilstarves and freezes)
Old 03-14-2007, 08:38 PM
Barker87's Avatar
are you sure?!
Old 03-14-2007, 08:39 PM
notanymore's Avatar
i thought the inertia switch was just for airbags? guess you learn new things every day
Old 03-14-2007, 08:43 PM
deserttoy84's Avatar
Come on now.... we own toyotas not fords. I know all about ford rangers and inertia switches LOL. they randomly tripped somtimes even when your not moving. just oen more reason to no like ford trucks
Old 03-14-2007, 08:46 PM
marko3xl3's Avatar
I know for a fact that airbags use a deceleration sensor (I guess you can call that inertia). But I thought that the whole fuel pump shebang is controlled by the airbag ECU once it itself trips the airbags if Toyotas even have the fuel cutoff feature. I wouldn't know for sure...
Old 03-14-2007, 08:54 PM
Barker87's Avatar
Ok so there is no inertia switch, are you 100% sure?
Old 03-14-2007, 09:18 PM
Staff
DeathCougar's Avatar
There is no Inertia switch in a Toyota.
It relys on input from the airflow meter in some cases, crank sensor in other cases (late model) You can turn the engine to on, without starting it, and fuel will not be pumping. If you dont believe that, for those of you with cold start injectors...turn the Ignition to on (dont start it) and crack open the 12mm banjo bolt leading to the injector. Fuel will come out, but it will not continusly spray. If you leave it cracked open and turn the engine over, fuel will spray out of there.
btw, thats also a good quick/cheap trick for checking to be sure the fuel pump is working.
Old 03-14-2007, 10:09 PM
Barker87's Avatar
Ok so I'm still screwed well I guess I'll see what that guy with the diagnostics says, thanks
Old 02-12-2018, 08:21 PM
Morgan Feemster's Avatar
Dose any one know if a 2007 fj has an inertia switch not getting any power to the fuel pump Brand new fuel pump and relay btw
Old 02-13-2018, 07:13 AM
akwheeler's Avatar
Find a wiring diagram and troubleshoot with a test light or multi meter. A wiring diagram for your vehicle will show if there is an inertia switch (I'm 99% sure it won't as stated above this is more of a Ford thing and not just their pickups) and without the diagram you are flying blind, check the fuse first.
kawazx636
10-06-2021 03:03 PM
beltcutter
09-30-2015 06:14 AM
PNW94Runner
09-29-2015 02:55 PM
charlie_fong
09-27-2015 10:06 PM
runnermedic
13
09-21-2015 05:20 PM
Quick Reply: Inertia Switch?
