idler pully tensioner broke!
Old 01-08-2009, 06:00 PM
stockyotadriver's Avatar
alright, so i have a 1989 pickup with a 22re and a 5 speed.
there is a belt that looks like it runs some type of smog/air pump and it runs down to the crank and up to an idler arm pully at the top. there is a tensioning bolt to tighten the belt up.
i was trying to tighten my belt and the bolt just snapped because it was over tightened, so now the only thing holding the pully is the main shaft bolt going through the center of the pully. and the tensioner bolt is completely broke off.
i used a pry bar and got the belt tight and tightened the pully down hoping it would stay. do you think it would vibrate loose and change positions?
also where could i get this part, the auto parts stores dont even carry it.
Old 01-08-2009, 06:07 PM
Rocketwrencher's Avatar
It should hold for a while. The reason why it broke is because you tried to tighten it without loosening up the bolt that holds the barrel nut together. You can get a replacement bolt at the toyota dealer.
Old 01-08-2009, 06:08 PM
jsn_stockard's Avatar
PM girlzlikemud2 , she can prob set you up.
Old 01-08-2009, 06:10 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
PM DeathCougar.
Old 01-08-2009, 06:14 PM
i did actually loosen the main shaft or barrel nut whatever you wanna call it. i tightened it quite a bit, and it got stiff, and then being a dumb a$$ i tried to tighten it more and it snapped.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
Dale Johnston
11
10-31-2015 10:22 PM
Obmi
10-04-2015 11:30 AM
puddlepirate
09-29-2015 08:02 PM
Quick Reply: idler pully tensioner broke!
