Idle Screw On TB Rotates Over Time
Old 10-30-2009, 03:30 PM
OutlawMike's Avatar
For the last few weeks I have noticed that the idle on my Runner was getting high, again. I shorted the test connector, adjusted the idle and timing, good to go. I though this was odd, so I marked the position of the idle screw in the TB. It is really easy to turn. Yup, last night I got home and saw that it had moved about 1/16th of a turn.
Any ideas on what to put on the threads to tighten it up?
I thought about teflon tape and or some type of thread locker, but I don't want anything getting loose and getting sucked into the motor.
Thanks,
Mike
Old 10-30-2009, 03:43 PM
abecedarian's Avatar
Pull the screw out and replace the o-ring on it.
Old 10-30-2009, 05:16 PM
DupermanDave's Avatar
could you use some loctite?
Old 10-30-2009, 09:09 PM
OutlawMike's Avatar
Thanks Abe, I did not even know there was an O-Ring on there. That will definitely do the trick.
Always something new to learn.
Mike
skoti89
07-06-2015 07:45 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Idle Screw On TB Rotates Over Time
