How to tighten antenna base to fender?
Old 01-10-2010, 08:25 PM
JJ'89's Avatar
How do I get to this thing? I cant see a way to it from under the hood or from inside the pickup. The old antenna was catching on a rose bush and I guess loosened the mounting. I got a new stubby antenna works good and just need to tighten the base against the fender. Thanks, Jim
Old 01-10-2010, 08:35 PM
Elton's Avatar
turn the shiny sliver ring
Old 01-11-2010, 06:49 AM
slacker's Avatar
accessed from inside the wheel well .... you need to unbolt the inner splash shield to re & re
Old 01-11-2010, 07:38 AM
rangerruck's Avatar
above dude is dead on...
Old 01-11-2010, 09:06 AM
Philbert's Avatar
+1
I discovered this when I had to replace the PO's stubby antenna that was torn off by some jackass. I also found out that the reason my passenger side floor boards always filled with rainwater during storms was that the PO hadn't used any kind of grommet for the radio antenna when he installed the stubby....grrrrrrrr.
Old 01-11-2010, 09:10 AM
xxxtreme22r's Avatar
hmmm sounds like my problem too, but its the stock mount, I guess when they redid mine, the idiots didn't tighten it enough and it got lost, it was flopping around on mine for about a month till i got tired of smacking my face on the antenna. My lazy ass fixed it by super gluing it to the fender lmao.
Old 01-11-2010, 07:52 PM
JJ'89's Avatar
Thank you sir!
Old 01-11-2010, 08:01 PM
iamsuperbleeder's Avatar
is it leaning all the way over, like off to the side?
if so, then you probably need a new antenna assembly...
you'll see the plastic tube-like thing in there when you pull the inner fender away; those are prone to breaking over the years, causing a loss of support, thus the antenna leans over
mine was the same way when I first picked up my 91
Old 01-11-2010, 08:03 PM
2DoorRunner's Avatar
Go to shucks and pick up a rubber antenna. They are like a foot tall, and have a ball mount so you can bend them over when you go wheelin. Oh, and they are only like 20 bucks.
You can install it in like an hour if you pull off the fender.
Old 01-13-2010, 11:05 AM
elblako91's Avatar
Good thread! Mine just came loose. Guess the wind was just to much for the poor thing.
Old 08-07-2015, 04:05 PM
norse's Avatar
I don't see anything under the fender to tighten. Lost a mudflap clip in the process. Will try to figure out a clever way of tightening the castle nut on top. Would be interested in replacing the antenna with the one mentioned above.
Old 08-07-2015, 08:21 PM
RAD4Runner's Avatar
You don't say what truck-year you have. On First-gen, just use long-nose pliers to tighten the castellated nut.
I have fiberglas cab on first-gen Morefunner, and rod antenna gets in the way of loading my kayak on roof so I deleted the rod antenna
Old 08-07-2015, 09:02 PM
norse's Avatar
Sorry. 5th gen. 1991 2wd p/u. Thanks, and have a great weekend.
Old 08-08-2015, 06:32 AM
Staff
Terrys87's Avatar
Below is how I fix my broken antennas. I cut the head off of a bolt and then thread the two broken pieces back together with the broken bolt. The castle nut holds the top of the antenna.
Copied...
Not the best picture, but in the top picture you can see the bolt in the top half of the antenna.
I just found a bolt that threaded into the two broken pieces and cut the head off twisted them together. I have done this before and it works great.
Broken
Twisted into one fixed piece.
live4soccer7
05-11-2016 06:52 PM
Kamaloha
10-16-2015 05:13 PM
Obmi
10-04-2015 11:30 AM
zombie_barbarossa
10-02-2015 10:54 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: How to tighten antenna base to fender?
