High idle(22RE)
Old 11-02-2008, 03:19 PM
yotakid825's Avatar
Question High idle(22RE)
so when I start it when it's cold it idles at 900-950rpm until I burp the throttle then it idles at 1150-1200rpm. after driving a bit it idles at 1450-1500rpm when I let off the gas(push in the clutch). when I hit the brakes it jumps back down to 1150rpm and it will stay there . then I'll take of again, push in the clutch(coming to a stop), back up to 1450-1500rpm. when I hit the brakes, back down to 1150rpm . It will idle at 1150rpm all day. the idle screw on the TB is all the way. I'm 90% sure it's vac. leak, but where?
another problem(maybe be related, but I don't think so) is I'm driving for like 5-10min and I notice that the temp gauge is almost in the red then like a min later the gauge reads normal or in the middle. so I have no clue other than I know somethings messed up in the cooling system
any help would be great
Old 11-02-2008, 06:31 PM
bryonb's Avatar
Your overheating may be a air bubble or air pocket in your cooling system. I had the same problem in my van Just take the radiator cap off and run the engine watch for large air bubbles. It may take 10-15 minutes to clear.
Old 11-02-2008, 07:35 PM
abecedarian's Avatar
If you start the engine cold, and don't touch the throttle at all for 15 minutes what does it do?
what year is the 22re?
Old 11-03-2008, 09:16 AM
yotakid825's Avatar
the truck is a '94 and the PO put a rebuilt engine in so the engine has a little less than 20k miles on it.
I started it and it idled at 900-950rpms and 15min later it was idling at 1100-1150rpm. after the 15min I tached it to about 3000rpms, when I let off the the gas it went down to 1450-1500rpm, when hit the brakes it jumped down to 1150rpms again
Old 11-03-2008, 09:34 AM
scuba's Avatar
when you say it gets red during startup that sounds like the thermostat to me...
redneck17
10-29-2015 09:09 PM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
ZONAYODA
07-13-2015 07:17 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: High idle(22RE)
