Hard to shift into first gear from nuetral
How bad is it? Unfortunatelly only time can tell. You could screw up your tranny syncros, linkage etc.
You may find that you can use less force if you put it into 4th, then quickly move into first.
If you end up replacing the clutch, get dealer parts. I've had to redo many clutch jobs because the shop manager kept getting cheap aftermarket clutch kits. I finally refused to do them unless they got dealer parts and never had any more problems.
Seattle_Sign_Guy
07-12-2015 12:38 PM
Jnkml
07-06-2015 01:20 PM
