front and rear IFS?
the only reason i'd put IRS on a truck is if it was a street-only rig set up for racing, or an extreme dune jumper. other than that, there isn't really any point.
Originally Posted by LOCKnGO
Thats pretty cool. I like the brake setup
i don't like the idea of inboard brakes. on a standard setupl, the only thing that can cause the brakes to not work is either a brake failure(duh) or the hub coming out. on that, if you pop a u-joint or the shaft fails, you have no brakes at all.
#25
True.... they are also more open to mud and gunk, but I would presume they have some benefit since expensive rigs like Jag run them. I know that on the hummer they provide better breaking due to the additonal gear reduction at the hub, so the brake has more effectiveness at lower speeds.
XtraCab
04-12-2020 05:25 AM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
jerusry
10-19-2015 05:28 PM
