Engine Vibration
Old 07-19-2009, 07:19 AM
buckz6319's Avatar
Old 07-19-2009, 09:03 AM
buckz6319's Avatar
Old 07-19-2009, 10:57 AM
buckz6319's Avatar
Base timing mark on the crank pulley moving
Old 07-19-2009, 03:37 PM
buckz6319's Avatar
Old 07-19-2009, 05:55 PM
  #25
abecedarian's Avatar
The drop in RPM's is normal at idle- the output from the alternator is lowest at idle and any significant electrical load will cause the alternator to try and output more amperage but it can't so the engine slows down from the draw. You'd probably notice your headlights would dim too if you had them on when at idle and operating a window.
#6 plug looks like it's getting a bit more fuel than the others. notice how the insulators on the first 5 are much lighter? try changing the plugs for stock denso replacements, none of the platinum or iridium things, and verify the gap is set per spec. then see how the vibration goes.
Also, it's normal for the timing to fluctuate when the jumper is not inserted. What I find odd is the timing is actually going below 10 with the jumper removed. That's sometimes caused by the knock sensor picking up something.
Old 07-20-2009, 02:25 AM
  #26
TNRabbit's Avatar
The FSM says set the timing with the jumper in place to 10 degress BTDC; when you remove the jumper it should go down to 8 degrees. Now, if it's HOPPING around, that could indicate a bad distributor...
Old 07-20-2009, 02:36 AM
  #27
buckz6319's Avatar
Old 07-20-2009, 07:50 AM
  #28
buckz6319's Avatar
Old 07-20-2009, 09:26 AM
  #29
TNRabbit's Avatar
Originally Posted by buckz6319
TNRabbit..thanks for the input...as you can see the timing mark on the crank pulley does jump around....so does that consitute a bad distributor?
Not necessarily the distributor but that's what I'd guess as the likely culprit.
Old 07-20-2009, 10:07 AM
  #30
camo31_10.50's Avatar
check your air/fuel ratio?????...maybe..idk..lol
my motor vibrates a little to..although it idles at 800rpm and is cammed..lmao
Old 07-20-2009, 02:15 PM
  #31
buckz6319's Avatar
Old 07-20-2009, 04:45 PM
  #32
buckz6319's Avatar
still working on it
Old 07-24-2009, 08:27 AM
  #33
buckz6319's Avatar
abecedarian
I went to the parts store this afternoon and ordered the Denso plugs just the factory stock ones will be here in the morning
Old 07-24-2009, 09:02 AM
  #34
Kiely's Avatar
...noise trying to catch up with the rpms of the engine and when it does then some vibrations smooths out but not much...
I know it has already been said but that makes me think torque converter.
Also have you checked for vacuum leaks?
Old 07-24-2009, 02:58 PM
  #35
buckz6319's Avatar
Old 07-25-2009, 04:05 PM
  #36
buckz6319's Avatar
Old 07-25-2009, 05:26 PM
  #37
buckz6319's Avatar
Old 07-28-2009, 02:43 AM
  #38
buckz6319's Avatar
any opinions on a possible........ "lockup shudder"...has anyone experienced this?
Old 08-04-2009, 04:35 PM
  #39
buckz6319's Avatar
I found a BAD MOTOR MOUNT
Deleted moved to a new thread for quick response
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Engine Vibration
