electrical probs
Old 07-22-2012, 05:52 AM
swerks's Avatar
electrical probs
What does this cube do ?? I think this wire may be my problem
Old 07-22-2012, 06:06 AM
My99's Avatar
That doesn't look factory to me... DO you have some aftermarket electrical accessories - winch/lights/sound system? What is your electrical issue?
Old 07-22-2012, 08:12 AM
swerks's Avatar
I dont have any accesories. my truck clicks once then looses all power, clock, radio, every thing. I move the white wire around a little and it starts up stays running with no probs. does not do this every time but enough to be problematic.
Old 07-22-2012, 11:16 AM
My99's Avatar
Well, you say you have a turbo, so I can't assure you that wire is not factory. I'm just saying it doesn't appear to be from my experience. Generally you don't see inline fuses in factory setups. You need to find out where those wires originate and terminate in order to start addressing the issue.
Old 07-22-2012, 03:24 PM
scope103's Avatar
The end terminations on the wires to the "cube" are cheap hardware-store "crush-type" fittings, which have no business anywhere near a truck. So you have a modified vehicle, and you'll need to just generate your own schematics.
The "cube" is almost certainly a relay of some sort, but obviously I can't discern its function on your truck.
The white wire could be a fusible link. If partially "blown" it would act as you describe.
Good luck straightening all of that out.
Old 07-22-2012, 05:13 PM
rworegon's Avatar
Time to start following wires from the relay 'cube' to figure out what the are doing. Where does that white wire go? The problem may be there in that yellow butt connection....there are a terrible way to connect wires in a vehicle.
Old 07-22-2012, 05:18 PM
hoe_nah's Avatar
Is that white wire going into the fuse box? Possibly the alt wire? Check your battery should have one short wire coming from the fuse box
Old 07-28-2012, 09:05 AM
swerks's Avatar
more help needed how do I remove the 80 A fuse ? also what is this adapter for ?
Old 07-28-2012, 01:16 PM
swerks's Avatar
I believe I have found my problem the grey cube, a hella relay just clicks vey loudly when I try to start my truck. problem is it apears to be a german part any I cant find any cross reference. its a hella 4RD 388-47 2012557C1 any help out there Please !!!
Old 07-28-2012, 01:23 PM
scope103's Avatar
https://www.yotatech.com/forums/f116.../#post51635492
When you refer to "this" in a picture with 1,000 parts, the best anyone can do is guess. Use Windows Paint (included for free in very version of Windows since 3.1) to draw a box or an arrow or something right on the picture.
Old 07-28-2012, 02:18 PM
swerks's Avatar
sorry, I didnt think it was needed the adapter thing in the middle of the pic that is non factory is what I was refering too.
Old 07-28-2012, 03:01 PM
scope103's Avatar
I think you're just guessing wildly. What do you think the relay is supposed to do? Why do you think clicking "loudly" is a problem? Lots of posters have suggested you're going to have to (eventually) trace out the wiring to find out what that relay does. (Isn't "Hella" a manufacturer of lighting? It would make a little bit of sense that Frankenstein wiring is there to run "big-bad" lights.)
[Don't worry about the cross-reference. Any 12v relay with the correct contacts will almost certainly work. Since I can only see 5 pins in your photograph, it's probably a SPDT relay, and one of the two "throws" is unused. But it's easy to tell when you figure out what it's supposed to do.]
In your picture with the "adapter", almost everything in the picture is non-factory. And if the adapter is non-factory, how would anyone be able to tell its purpose from that picture?
As others have told you, you have to trace through the wiring from the starter back to the panel, to find out why the starter is not getting power.
Good luck.
Old 07-28-2012, 06:51 PM
swerks's Avatar
I suspect the relay because it never made that sound in the past. the wires are power, ground, starter solenoid, and one goes into the wiring harness, not sure on that one. yes im guessing wildly thats why im asking for help.
Old 07-28-2012, 08:29 PM
scope103's Avatar
Sounds like a homemade "hotshot." (A relay to take the solenoid current away from the starter switch.) You're making progress.
You have a multimeter, I hope. http://www.harborfreight.com/7-funct...ter-92020.html Measure the voltage to ground at each terminal of the relay. With key on, you should get 12v at "power," 0 at the rest. With key in start position, you should hear the relay close (however loudly), and you should get 12v on the solenoid wire. The wire that goes into the wiring harness is almost certainly 12v when the key is turned to start, and if you can hear the relay that part is probably good.
If you hear the relay close but get 0v on the solenoid line, the relay is bad. But if the "power" lead drops to anything less than, oh, 12.0v that lead is bad (too high resistance). (You were talking about the problem coming and going when you wiggled a wire -- that could be it.)
If the relay is bad something as simple as this will do: http://www.parts-express.com/pe/show...ource=googleps
If you get good 12v on the solenoid line but it won't turn over, the problem is in the direction of the starter.
Old 07-29-2012, 05:17 PM
swerks's Avatar
so I got my multimeter and I do get power to the starter solenoid but only for about 1 sec then nothing it seems its not even there enough to get the starter turning. I need to remove the key to even be able to make another attempt. could possibly be ignition problems ???? yes im guessing wildly again. will do more investigating.
Old 07-29-2012, 05:40 PM
hoe_nah's Avatar
With your multimeter check voltage to starter without key.
now turn key to on position and check voltage to starter
Idk what this is coming off the positive side batt cable, get a new one and wire it up correctly and see what happens
Also what are those small wires coming off the positive side..what are they for
Old 07-30-2012, 06:52 AM
swerks's Avatar
https://www.yotatech.com/forums/f116...-click-246509/ this sounds like it could possibly be my problem
Obmi
10-04-2015 11:30 AM
bryan34w
12
09-30-2015 02:50 PM
voiddweller
09-28-2015 11:21 PM
Project90
09-24-2015 11:40 PM
xzen73x
09-14-2015 03:00 AM
Quick Reply: electrical probs
