Electrical Problem. Need help.
Old 04-26-2009, 11:06 AM
hoppa's Avatar
I just installed a 120 amp alternator, I installed 5 ga. cable from the alternator to the fuse box. I also installed a 5 ga. cable from the other side of the fuse to the battery, also installed a 120 amp fuse in place of the 80 amp.
I hooked evey thing back up and I have no power to the inside of the cab (dash lights, starter clock). Ther is power to the fuse panel in ds kick panel because theres a relay clicking when I turn the key.
The head lamps work the hazard lights work. I checked all the fuses in the kick panel and uder the hood all seem good.
Its an 88 4 runner and was working fine before the swap except for the batt and charge lamp staying on which is why I replaced the alternator.
Any help would be greatly appreciated.
Thanks
Old 04-26-2009, 12:12 PM
hoppa's Avatar
Never mind I got it.
Old 04-26-2009, 12:50 PM
elblako91's Avatar
what was it?
Old 04-26-2009, 02:57 PM
desert-rat660's Avatar
dead battery?
Old 04-28-2009, 03:02 PM
hoppa's Avatar
Aparently there is something in the stock harness that is needed for the cab to have power. I wired up the stock charge wire and walah, power.
As soon as I get more time ill figure out what I missed and go back with the 5 ga. cable.
Old 04-28-2009, 04:54 PM
dntsdad's Avatar
hmmmm......never even heard of 5 gauge cable before.
Old 04-28-2009, 11:52 PM
wyoming9's Avatar
I was also thinking the same thing.
I have never seen that size in the United States .
What did you use???
Old 04-29-2009, 07:35 AM
TNRabbit's Avatar
you can use the stock wire AND the 5 gauge cable directly to the battery in tandem. Problem solved.
Old 04-29-2009, 11:26 AM
mt_goat's Avatar
Yeah IIRC the stock harness splits off and one group of wires goes into the drivers side fender (maybe to the in-cab fuse box ) while the rest go around to the under-hood fuse box. I'm running dual or tandem alt cables with no problems.
Old 04-29-2009, 11:33 AM
AZkid's Avatar
oh my god! thats whats wrong with my truck!! same exact thing!!!!
Old 04-29-2009, 11:47 AM
mt_goat's Avatar
Yeah you see it in this pic, the lower white cables are the stock harness unwrapped up to the split (1&2). The upper black cable is the one I added:
markwink
08-18-2015 12:38 PM
izzmee
08-17-2015 10:20 AM
corey519
08-12-2015 11:12 AM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: Electrical Problem. Need help.
