ECU V6 3.0 compatability
Old 01-31-2008, 12:31 PM
rgrounded's Avatar
Hello, I posted this same ? in the newbie section and havn't got much of a response so I thought I would try again. I have a 1989 SR5 4x4 that I would like to replace the ECU . My ? is what ECU's might interchange.Its got a 5 speed M/T, 3.0 V6 3VZ-E , The #'s on the ECU in it now are 89661-35191 3VZ NH. I was getting a code 22. I have replaced the temp sensor and temp switch and short of running every test on ohms and voltage and removing fuses ground wire ,ect. The code will not go away and the check engine light won't go out. Any suggestion would be greatly appreciated. Thanks Rob P.S. I have seen a few ECU's on Ebay and if I thought they might interchange I would try one. (what years and #'s might be the same)
Old 01-31-2008, 01:28 PM
dcg9381's Avatar
You'll have to dig.. someone on here and on pirate there is a photo of 22RE ECUs, years and information - might give you some indiction of interchange. I think it had the 3.0L listed also.
If you were to try it w/o the listing, I'd buy something as close to my year as possible and with the same transmission...
Old 01-31-2008, 01:30 PM
dcg9381's Avatar
Ahh.. I've got it - here it is.. Dunno if this includes the 3.0 or not:
Old 01-31-2008, 02:05 PM
Marc's Avatar
Don't know if this will help but at the bottom of this page you can put in ECU mumbers.
http://www.ecudirect.com/oem/
Old 01-31-2008, 04:38 PM
rgrounded's Avatar
ECUDIRECT.com thanks but they only cross referenced to their pt.# 299.99 for a R&R little rich for my blood
Old 01-31-2008, 05:12 PM
Elvota's Avatar
I actually have a '90 5spd ECM for sale. I can't give you a definitive answer on compatibly though.
Old 01-31-2008, 05:52 PM
rgrounded's Avatar
thanks but I just noticed your pin configuration is different than mine. Mine is 10-18-24...Thanks Rob
Old 01-31-2008, 07:30 PM
Elvota's Avatar
Interesting that they'd be so different. Your ECM is missing a heck of a lot of pins for just one year different. Wonder what Toyota added between years?
Old 03-15-2023, 03:25 AM
Pricemine's Avatar
Can a 3vzE ECM work on a 3vzFE engine 1989 Toyota V6 pickup 5 speed Manuel transmission.both 3.0 V6....
Thundar
10-31-2022 10:03 PM
yeehaw1
12-16-2010 11:33 PM
rgrounded
01-30-2008 05:19 PM
1990 LJ78 Prado
09-21-2007 03:31 AM
lobody94
09-23-2004 03:50 AM
Quick Reply: ECU V6 3.0 compatability
