Door LOcks dont work!:(
Old 01-16-2010, 03:32 PM
Jeremy11's Avatar
I've taken out the Door control from under my dash but i dont know how to tell if its broken.
When i click the passenger door lock/unlock there is a little clicking noise inside this box.
But nothing happens. When i click the drivers door there is no clicking noise at all..
I was just wondering why my door wouldnt lock with the switch.
Anything helps. Thanks in advance!
Old 01-18-2010, 08:24 PM
hunter4runner's Avatar
i am so confused
Old 01-18-2010, 08:43 PM
camo31_10.50's Avatar
fuse...
relay maybe? lol idk
Old 01-18-2010, 10:31 PM
aviator's Avatar
I would say it is one of two things depending on if the pax door switch works on it's own or not. Either a wiring problem between the control box and the pax door switch or a problem with switch in the door. If nothing works at all the wires to the door solenoid may be disconnected or corroded. The wires running into the door may also be crimped/broken/shorted.
I have a similar problem [driver's side unlock no work] and I've narrowed mine down to the door master switch (driver side) since everything else works as it is supposed to. I tried cleaning it with contact cleaner (had foo, thing apart too lol) but no soap... grabbed a new one in the yard... one day I'll get PO'd enough and install it.
Old 01-18-2010, 10:44 PM
85TurboRunner's Avatar
I betcha the gremlins did it.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Cplmike
07-08-2015 08:47 PM
mickyd9990
07-06-2015 09:01 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Door LOcks dont work!:(
