Old 03-30-2016, 02:40 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Fuel System Guides
Print Wikipost
Do I have to take the tank out for replacing fuel pump in 90 truck?
Old 09-02-2010, 03:08 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
x2, B+ and Fp are the two you jump...
Wanna do it faster and easier?
Undo the MAF meter and with the key turned on when you push the flapper, you should hear the Fp if it's quiet outside...
Get a friend to hold it and you can walk back there.
Old 10-21-2019, 03:56 PM
quediaka's Avatar
Fuel pump toyota pickup 85-94
Someone mentioned on YouTube that he made a diagram to access the gas pump opening a hole on the truck bed.
Old 10-21-2019, 04:05 PM
quediaka's Avatar
Fuel pump
Originally Posted by xxxtreme22r
you could always do it it like we used to do with the older fords and cut a hole in the flooring in the bed and do it that way and then make a patch panel out of what you cut out to pop in it's place.
It would be ideal, but where precisely to open access? they say there is a diagram on the internet with exact measures to open the hole
kazuya2416
06-27-2015 12:24 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: Do I have to take the tank out for replacing fuel pump in 90 truck?
