Disc Brake Swap... Mill the Axle Flange
Old 08-16-2011, 07:51 AM
  #41
RBX
RBX's Avatar
I'm 90% sure this is the way i will go, unless someone gives me a compelling reason this is NOT a good idea.
Old 10-03-2011, 08:11 PM
  #42
Motorheadno13's Avatar
Any progress on the separate e-brake caliper setup? This sounds promising.
Old 10-03-2011, 08:26 PM
  #43
paynemw's Avatar
what about the new T4R's? and their rear discs?
Old 10-04-2011, 05:14 AM
  #44
RBX
RBX's Avatar
I guessing the new 4Runners rear disc setup is pricey.
I recently purchased a Kodiak mechanical caliper, meant for a large trailer. So, as of now, I'm looking into making a transfercase brake for under $150. Caliper I am using is a full caliper unlike the trailgear/sky and cost 80$ locally. Now I need to source a disc of the proper size, or have a piece cut out for this project.
Old 10-04-2011, 06:26 AM
  #45
Outsane's Avatar
waiting for you to do all the work so I can copy..
thanks!
Old 10-06-2011, 04:25 AM
  #46
RBX
RBX's Avatar
Edit:
The Caliper pictured above, would not work, it rubbed the wheel, and clearancing those calipers is not an option because of their design.
I ended up using single piston front calipers from an 1980 Corolla, i will get into specifics in my build thread when i get the parking brake set-up.
Old 10-06-2011, 06:54 AM
  #47
Outsane's Avatar
I like this progression... since I have my SFA calipers to put on the rear, and can still potentially add an ebrake
Old 10-11-2011, 01:03 PM
  #48
Outsane's Avatar
Ford Taurus brakes..
http://www.pirate4x4.com/forum/showp...&postcount=145
get it done!
Old 10-11-2011, 04:40 PM
  #49
RBX
RBX's Avatar
Not Toyota, I don't want to carry extra tools that aren't metric. I'll be updating my build thread with the ebrake fab stuff.
Old 06-06-2014, 03:27 AM
  #50
RBX
RBX's Avatar
Well I ended up going with Supra brakes...but...seems like I was onto something....
92 Subaru Loyale Calipers.
I am never satisfied with my brakes, this may be a future mod.
Flying91
45
04-11-2024 04:39 PM
nvdesertrunner
05-11-2020 08:18 PM
09-04-2015 09:27 AM
priest16
15
08-06-2015 07:43 AM
bobpat
08-01-2015 09:25 PM
Quick Reply: Disc Brake Swap... Mill the Axle Flange
