Definitive Temp Gauge Fix!
Old 12-10-2017, 05:42 PM
  #61
881stgen's Avatar
I did this, and like some others, I didn't see any broken wires. But, also like some others, when I reassembled everything the gauge seems to work much better. Thanks!
Old 01-24-2018, 03:10 PM
  #62
YotaRick27's Avatar
The electronic mat behind the gauge cluster for the same style where would i find a new one mine melted?
Old 03-06-2018, 06:42 AM
  #63
Indetrucks's Avatar
I will be trying this.
Noticed my temp gauge on the 87 4Runner reading hot when cold sometimes.
Old 08-25-2018, 06:29 PM
  #64
outdoorjunky's Avatar
keep in mind that the temp gauge sender could also be a problem for some with this issue and it's the sensor with the spade connector on the lower intake between cylinder 2 and 3 smack dab in the middle of the lower intake right up next to the valve cover. If you put a lead on the wire end and ground it to the chassis or block the temp gauge in the truck should turn all the way to hot if the gauge in the truck works. that tells you the sender unit is bad not the gauge. I had that issue where mine, it was jumping around and reading at only about 1/4 low temp most of the time, I tested it and the result pointed at the sender not the gauge then I got a replacement sender at the junkyard and all is well. Actually for anyone planning to tear in to their cluster it's was easier to test that the gauge is good or bad from the wire to the sender unit on the intake than it is to bust open the dash to find out that's not it . good writeup on fixing the cluster though I'll bookmark this incase my gauge end ever breaks on me.
cheers.
Old 05-01-2019, 07:22 PM
  #65
Samson3113's Avatar
Thanks
Excellent write up and pictures. Kudos. Can you tell me any links to removing cluster. Everytime I start I get stuck trying to find out how to get to the Speedo cable
Thanks
Jim
Old 04-30-2022, 12:28 PM
  #66
skbrdjk13's Avatar
Hello, old threat but hopefully someone sees this. Great info on this repair, took my cluster apart, found the 3 nuts for the temp guage not as tight as id like, no wires broken, but i did notice when i put my screw driver on one side of the winding, my guage will go up to over half way, does not do that on any other side of the winding. Is that telling me thats where my problem is?
Old 05-26-2022, 08:12 PM
  #67
TConover's Avatar
Great write up!!! I"ll have to try this with my instrument panel, for years it has been behaving as you mentioned. Can't wait to have a temp gauge I can trust!
Old 11-26-2022, 12:10 PM
  #68
GreaseMonkey64's Avatar
Works on sr5 cluster as well
I took apart the cluster for my 91 sr5 and while the gauge is slightly different it is the same repair.
Old 03-27-2023, 04:46 PM
  #69
MAYBERRY's Avatar
on the screwdriver moving the needle, is your screwdriver magnitized maybe?
Old 05-30-2023, 02:39 AM
  #70
mi_guy616's Avatar
I wish I'd seen this thread before i replaced my altimeter with gauges. I do keep a better eye on the engine vitals with the new location.
The following users liked this post:
dfb2002 (04-25-2024)
Old 06-11-2023, 03:34 PM
  #71
skbrdjk13's Avatar
sorry for the late reply, but I don't remember which screw driver I was using, the screw driver itself was not magnetized, but I may have been using my snapon mini screw driver that has a magnet at the end of the handle
the1998sr5
15
07-14-2020 08:35 PM
gary4runner
09-24-2015 12:53 AM
Nickyodaman
07-27-2015 12:13 AM
Jeffreynmandy
07-18-2015 08:26 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Definitive Temp Gauge Fix!
