Cost of going from R12 to R134?
Old 07-17-2010, 04:54 AM
TORTIS's Avatar
I was wondering what the cost was to go R134 from R12 in your areas?
After A guy told me 8-1000 to do the job, I went and bought an A/C kit from ACKITS for 400 bucks, and will do it myself.
I replaced the compressor on my Tundra yesterday, and used the new tools to vacuum and charge the system.
After I do the 89 truck, the tools will be paid for with the savings.
Old 07-17-2010, 05:22 AM
waskillywabbit's Avatar
Converted my 84 for under $150
Old 07-17-2010, 06:12 AM
norcal707's Avatar
I'm not to sure but what I know all you have to do is change all the gaskets and seals to convert gases. right?
Old 07-17-2010, 07:38 AM
TORTIS's Avatar
Brian you must have done all the work yourself at that price?
NorCal, I think you have to flush the system.
Old 07-17-2010, 08:13 AM
swampfox's Avatar
i put the adapters on the lines on a 86 i had and put the r 134 in. a air conditioner man told me by the time the seals and other parts gave any trouble, it would most likely need work any way. i spoke to the man i sold the truck to and after 3 years it was still working good. i am not going to say it was right or not but that is my 2 cents.
Old 07-17-2010, 10:55 AM
Changed out everything needed. My buddy Jon did the work, flushed, recharged everything.
Old 07-17-2010, 11:32 AM
morena67's Avatar
Sorry guys, but, what is the gain from changing the sistem?
Thanx.
Old 07-17-2010, 11:36 AM
TORTIS's Avatar
It takes freon to make the A/C system work.
Old 07-17-2010, 04:58 PM
thralldad's Avatar
Green o-rings $10, receiver-dryer $25, recharge kit $45, vacuum pump -free loaner from Auto-zoo
Old 07-17-2010, 05:08 PM
camo31_10.50's Avatar
i was under the impression that it was just the fittings that were different...
my '86 has already been converted though
pretty sure my '92 is R-134 too, right?
Old 07-17-2010, 05:48 PM
1990yota-pickup's Avatar
i need to learn as much as possible my truck didnt come with a/c.. and it sucks to drive it the hot summer days...
i got a few parts but i really havent looked into everything i need to set it up.
Old 07-17-2010, 06:05 PM
bgordon45's Avatar
I'm converting to R134a while replacing a bad compressor on my truck. The dealer nearby quoted me $550 just for the R134a conversion.
Picked up a new compressor ($215), drier ($15), and expansion valve ($10) from ackits.com.
Green o-rings ($10) and 4 R134a service ports (2 hi / 2 low - $20)
I also bought some flush ($15) to purge the lines
Old 07-17-2010, 06:09 PM
i wonder how much toyota would charge to install a complet a/c sytem in my truck?
gotta start out with the highest quote first
Old 07-17-2010, 06:11 PM
TORTIS's Avatar
ACKits.com are good people with a good forum. I bought some nitrogen from the local welding supply house to purge/dry everything after the flush, when I do the 89 truck.
I hope it gets thru this year.
Old 07-17-2010, 06:13 PM
TORTIS's Avatar
my guess 13-1500 bucks
Old 07-18-2010, 08:23 AM
i say it would be money well spent to do dam hot in the south no to have a/c..
Old 07-18-2010, 09:33 AM
norcal707's Avatar
$800 to $1k is tooo much.
Old 07-18-2010, 02:31 PM
ldivinag's Avatar
i coulda sworn a few years ago, someone came up with a R12 clone that was good for the environment and 100% compatible...
Old 07-18-2010, 02:55 PM
ya, stacey david was talking it about either when he hosted trucks, or while he started hosted gearz
i think its called duracool
it is
go to this link for more info
http://www.duracool.com/
Old 05-22-2020, 03:26 PM
Johnny Gray's Avatar
Be very careful.
Hello, I think you should take into account that doing it yourself may be inexpensive, but if you do one thing wrong, or just leak all the Freon into the atmosphere and are reported, then that’s a $20k fine and prison time.
Quick Reply: Cost of going from R12 to R134?
