Control Arm Bushing replacement?
Old 04-13-2016, 10:22 AM
mar4k's Avatar
Im going to replace the lower bushings on my '02 Double Cab TRD. Do I need something to compress the shock?
Old 09-21-2017, 09:34 AM
Verunga's Avatar
for future references, these are a total kit for 124$, dont waste your money buying toyota fronts for the same price. Just spend a couple hundred hours replacing everything.
https://www.4wheelparts.com/Suspensi..._pn=D/I18-2003
Old 09-21-2017, 09:24 PM
mattyboi's Avatar
I replaced my LCA bushings last spring. Made sure I slathered a bunch of anti seize into them as well as the camber bolt. My old ones were seized and I had to cut them out with a reciprocating saw. Found a pack of 4 bushings (rubber) off ebay for about $60.
Pushing them out was also pretty hard. First I tried a 50 ton hydraulic press, bushings still didn't want to come out. It actually bent the arm a bit haha Hit it with heat and they finally popped out.
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
andrewtexas123
07-14-2015 04:29 AM
cyclist231
07-07-2015 12:56 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: Control Arm Bushing replacement?
