Code 25 95 4Runner
Old 04-18-2007, 04:57 PM
pruney81's Avatar
Code 25 95 4Runner
Well, i got a code 25 a few weeks ago so I replaced my o2 sensor because I had been getting 13.5 mpg around town. I've got 160k miles on my truck so I thought a new o2 would help mileage. It didn't do anything at all that I can tell. What else could a code 25 be? The check engine light only came on once and it came up with a code 25, I then disconnected the battery and it went away. What else could a code 25 be? Would a tired EGR valve affect gas mileage?
Old 04-18-2007, 05:12 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Code 25:
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
Happy hunting...
Old 04-18-2007, 05:16 PM
pruney81's Avatar
Ahhh..you said it.
Old 04-18-2007, 05:33 PM
thook's Avatar
hehehe....
Old 04-18-2007, 05:36 PM
gonzo's Avatar
Don't you have 2 02 sensors? Mine does
Old 04-18-2007, 05:43 PM
pruney81's Avatar
I only have one right before the cat as far as I can tell. Is yours a CA vehicle by chance?
Old 04-18-2007, 05:47 PM
gonzo's Avatar
not that I know of. I have 1 before the cat and 1 before the muffler
Old 04-18-2007, 05:48 PM
pruney81's Avatar
Mine was built in 9/95 and it only has one o2 sensor. I know the CA models had 2 o2 sensors.
Old 04-18-2007, 06:12 PM
gonzo's Avatar
I do know the the original owner. It was bought in NH.
All I know, but it does have 2.
Old 04-18-2007, 06:14 PM
Knuckles's Avatar
I do the the original owner.
you what!
sorry for the immature comment. i just found it funny.
Old 04-18-2007, 06:37 PM
gonzo's Avatar
LMAO
OPPS
I "know"
LMAO
There, fixed. lol
Old 04-19-2007, 09:49 PM
thook's Avatar
It was more interesting the other way...lol
Old 08-19-2016, 01:08 PM
Jason Holdeman's Avatar
Mine is also only giving a code 25....
And i am getting horriable fuel millage....
I have replaced my fuel injectors with a set from flamethrower, replaced my fuel filter, replaced my afm ( p.o. was inside it and dinnt make anything, was getting a 25 and 26 code till i did that)
Egr valve and pair valve delete so i can see the #5 plug now!!!
And the idle is sub par.....
I do not understand what is going on here im only getting a code 25 but like 7 miles to the gallon!!!!!
The only thing i have not checked is my fuel pressure, ignition, ecu, aand o2 sensor....
She only has 127k on her and has had a new heads put on in 05 at 105k....
smthwsn357
05-01-2024 07:28 AM
smiley52
07-11-2015 05:16 AM
Roger Borba II
07-09-2015 05:05 PM
Jnkml
07-06-2015 01:20 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Code 25 95 4Runner
