changing transfer case oil..
Old 10-07-2009, 11:47 AM
DupermanDave's Avatar
how many quarts are required for the manual transmissions?
(old thread, I know, but still need more information.)
-edit-
Found another good post with this info. 1 quart in the transfer case and 3 in the transmission?
Old 10-07-2009, 12:02 PM
Monochrome's Avatar
I put a little over 3 quarts in mine. I believe the FSM states 3.2 quarts.
Old 10-07-2009, 12:34 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
Old 10-07-2009, 11:40 PM
skinnadoor's Avatar
Originally Posted by highway
I got to change my transfer case oil and I am considering going synthetic. Would there be any problems with 190,000 on the clock ? what type/rating and how much oil do i need ? Year and model in my signature
highway
I just did my transfer case today along with my diff's, and transmission fluid. I used about 1.1 ish Litres of 75w-90 AGL synthetic.
After you fill her with new oil, take her out and cycle through all your 4WD settings on a dirt road to get everything nice and soaked inside the transfer. Myne was shifting very very smooth after new oil.
make sure you take the filler plug off before the drain as a rule of thumb...hehehehh OR ELSE !!
Old 02-04-2015, 08:53 AM
  #25
pickle's Avatar
Does anybody know the oil capacity of a Tranf case on a g52 trany ...since your on the trany project....never mind I found it on a link......!
Old 02-04-2015, 01:52 PM
  #26
coloyota1023's Avatar
Drain, and fill all the way til it leaks out the fill hole..
Old 01-11-2018, 04:52 PM
  #27
Renntag's Avatar
I had to fix a broken shifter and why not change fluid? I thought that I might be able fill through the case shifter. Drained the case With the fill plug removed i added the appropriate amount of fluid with none coming out the fill hole. Now the shifter port is full with fluid. <bangs forhead>.
i opened the trans fill port and it is as it is supposed to be.
So what cavity did the 2 to 3 quarts fill? Scratching my head. There is a puddle up to the top.
ooops.
Old 01-15-2018, 09:57 PM
  #28
Renntag's Avatar
Still no evidence as to where the fluid has gone. I drove the truck today and will again tomorrow. I will pull both the trans and case fill plugs to see if the extra fluid is making it's way into those areas and thus over filling them.
Old 03-08-2018, 11:51 AM
  #29
Renntag's Avatar
Still no idea where the fluid went.
I drained the case and filled it with fresh fluid. As stated above, I pulled the fill plug for the trans and the case, neither was overfilled after adding 3 qts to shifter port.
No leaks or strange-ness driving it. Bizarre.
SMOD
07-23-2015 10:29 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: changing transfer case oil..
