Cat glowing red after Seafoam treatment - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-28-2008, 05:42 PM   #1 (permalink)
Got back after driving about 6 miles following fuel up. When I stopped, I looked at my cat which is glowing red (its a dark night..).
Is this normal? I never noticed my cat glowing red like this.
__________________
88 4Runner 3VZE Auto 31x10.5 BFG AT KO's w/4.88's Detroit Softlocker Rear, TrueTrac Limited Slip Front, K&N intake, Jardin exhaust w/freeflow cat, TJM front Bumper/Bull-bar, Wilderness Roof-rack, Cobra CB, AutoZone floor mats, TRD keychain, etc...
cdphillips60 is offline
Old 02-28-2008, 05:45 PM   #2 (permalink)
stormin94's Avatar
No. You should have read the negatives of the seafoam treatment. It is not just some miracle fix it all. I doubt if anything is messed up, but check your O2 sensor(s). Did you add it to the gas, oil, or brake line?
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 02-28-2008, 06:02 PM   #3 (permalink)
Gas - the trucks been sitting for about a year and I need to get it inspected or the property owners association will give me fits. It's running rough and I hoped to clean up the injectors a bit and dry up any water that might have accumulated in the tank.
I got my oil test back from Blackstone Labs and it indicates glycol in the oil and metals associated with bearing wear. As such, I'm preparing to pull the motor and rebuild it but need to get the inspection sticker on it so I won't get harrassed..
I just never noticed the cat (any cat..) glow like that before..
__________________
Old 02-28-2008, 06:47 PM   #4 (permalink)
Wow, the magic elixer is spreading like a wildfire. Seafoam is basically diesel fuel with some doctoring. I'll catch he11 for this.
So why Seafoam? Pour it down an intake and what? To attempt to clean the back side of an intake valve, possibly carbon on a piston face and stress the CAT and O2? Not me.
Run Berrymans injector cleaner through your gas tank. For the money, the best injector cleaner period. Very strong solvent. May take two cans if really bad.
When I change my oil, I add a half quart of diesel fuel to the crankcase oil. Let the motor run for 10 minutes at idle. When possible, let it sit overnight. The diesel will start melting carbon and sludge on the piston rings and softening seals with no damage.
You are better off putting the Seafoam in the gas tank where it will dilute. Down the vacuum line only makes Seafoam happy and downstream parts unhappy.
My $0.02
SEAIRESCUE is offline
Old 02-28-2008, 06:56 PM   #5 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
if your cats glowing it means you have a clog somewhere
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 02-28-2008, 07:59 PM   #6 (permalink)
rowdy235's Avatar
question- did you notice the cat doing this before? Could just be, as ozzie said, clogged.
__________________
The Daily Driver:
1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock
The People-Hauler
1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock
The Dump Runner
1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust
FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916
rowdy235 is offline
Old 02-28-2008, 08:30 PM   #7 (permalink)
mr_schuster's Avatar
If the catalyst is glowing, your running to rich. Working for the dealer I have seen it on several occasions. 1st by sucking a cleaner through a vacuum line, 2nd a faulty ECM with bad parameters and 3rd an injector hanging open. If you want a good fuel treatment try a BG product called 44K which is added to the tank or try a cheaper alternative Chevron Techron. Fuel "induction" cleanings on a fuel injected vehicle do very little, but cost you you money. The cats probably fine however it could have damaged the 02.
mr_schuster is offline
Old 02-28-2008, 09:42 PM   #8 (permalink)
has anyone tried any of the fuel system cleaner by Ever-Wear? supposed to work WAY better than seafoam, and its 59.99 an application.. anyone?
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 02-29-2008, 09:31 AM   #9 (permalink)
Man, that cat was doing some serious work... If the engine was running rich (obviously due to this stuff..) it was doing a great job of clearing it up - there was no smoke of anykind. The cat is one of the high flow kind (I can't remember which mfr.).
I guess I'll not question the purpose of, or effeciveness of the cat ever again. I will, however, be much more cautious of where I park off-road, and what kind of stuff I put in the tank.
Hell, I could have lit my truck on fire... (or broiled a nice steak had I been more prepared) :o
__________________
Old 02-29-2008, 09:36 AM   #10 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
LOL Well this is a good way to prevent your cat from getting stolen... (At least in a parking lot right after you've driven it)
http://www.yotatech.com/f116/stolen-...verter-136161/
Anyway insiteful info about Seafoam vs other alternatives.
__________________
Molly
aka Lysmachia
93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Quote:
Originally Posted by http://www.textsfromlastnight.com/
(815): it was 5AM and you were field goal kicking solo cups into the sink
Lysmachia is offline
Old 03-01-2008, 11:02 PM   #11 (permalink)
Send a message via AIM to shaeff
I read this from a VERY knowledgeable person on another forum. Read it and draw your own conclusions. I'll never use Seafoam for what most of you guys do...
Quote:
Seafoam, as with many additives, consists of a solvent in a light oil carrier. Iirc in the case of Seafoam the solvent is naphtha. It works OK for dissolving fuel varnish because that's what it's designed to do. The problem with injecting it into your manifold is that 1) It's not very effective and 2) You end up burning the oil carrier. That's why it smokes so badly. Burning oil from any source isn't good for your engine and it especially isn't good for your catalytic converter if you have one.
I prefer using water for de-carbonization and using a top tier gasoline along with a PAE (polyetheramine) based fuel additive a couple of times a year. That'll keep everything including the injectors clean. Gumout Regane (the yellow stuff in the clear bottle), Redline SI-1, and Techron Concentrate are all PAE based.
I said what the consequences are in a recent thread. It was rebuked so I left it up to the members to decide. You have to remember I deal with this sort of stuff all the time so when I run into those who "know better" I back off.
I'll say it again: The product has it's uses but this isn't one of them. Using it this way only lightens your wallet and shortens the life of your cat without benefit. The product is mostly light oil. Where do you think all the smoke comes from? Since when is combusting oil in either the cylinders or converter good? Rich mixtures kill cats so oil won't? If it removes any carbon it'll only be a tiny amount. If all you have is a tiny amount you're doing more harm then good because a small amount works to protect the piston crown. Good thing it comes right back, which makes the "treatment" even more of a waste. If you want to clean excessive carbon use water injection, an overnight piston soak, walnut blasting, or any of the other *proven* methods. Once it's gone keep it at bay by regular use of a PEA based fuel additive.
Aside from all the other tests you could've done a simple way for verifying it's lack of effectiveness is to examine the motor, including the valves, before and after using a borescope. I have a surplus medical instrument I use for those jobs. It was originally designed for, well, lets just say it's been shoved inside far worse places than a motor. I would've suggested doing this except it's already been done by myself and many, many other people who aren't as gullible as most of the public. The results are always the same: it does squat. People who swear by it don't do science. They accept anecdotal evidence from others. Being ignorant is not the same as being a dumbass but imo anyone who uses something without understanding the science behind it, based on what others say who also don't, is.
At least you did some "research" even if it wasn't the best kind. And like most people you did it after the fact. Frankly, if I was going to rely on what others say about a product's effectiveness (and I never do) I'd sure as hell require a lot better than 50% odds before any cash came flying outta my wallet. And even if the product did work I'll point out injecting anything into the brake booster line results in a very poor distribution of it across cylinders. If you feel a need to dump stuff into your engine do it upstream of the plenum, through the throttle body for example.
As I said, the product has it's uses. It's popular with bikers for a reason. I ride also and used Seafoam in the fuel for years. The naphtha in Seafoam works well to clean fuel varnish in my Vulcan's carbs but after a bit of study and testing I found something that does a better job. Since you brought up Techron and I brought up PEA here ya go. It's the same stuff:
PEA is Polyether Amine. It's the active chemical in Techron and a few other aftermarket fuel cleaners. Chevron's Oronite Division is the inventor and world's largest supplier these days:
http://tinyurl.com/y8v5ad
PEA is used in varying amounts in almost every quality gasoline made. The problem is unless you use one from the day an engine is new or rebuilt it takes time to clean things up. That and the amount varies from one fuel brand to another. The way to overcome this is to use a PEA based cleaner a few times a year or with every oil change and a good quality fuel (www.toptiergas.com) in between.
Typical fuel cleaners are solvent based and therefore cheap. They don't do much other than make your idle nice and that isn't from any cleaning action. PEA cleaners cost more because PEA is expensive to produce compared to solvents but also far more effective. The leading PEA based cleaners are GumOut Regane (yellow stuff in clear bottle), Redline SI-1, and Techron Concentrate. Each of these products has any where from appx 30-50% PEA with RedLine SI-1 having a slight edge. The cheaper Techron ProGuard also contains PEA but at a lower concentration. Not a good value.
Gumout Large Vehicle Fuel System Cleaner in the gold bottle is also PEA based. It contains the same percentage of PEA as does Regane but in a different carrier. It's 20 oz size makes for a better value if you can find it. Be sure it says "fuel system cleaner" and not "fuel injector cleaner". The bottles look nearly identical but the fuel injector cleaner contains no PEA.
__________________
My heatercore replacement writeup with pics.
-'94 Toyota 4X4, 22re, 31X10.5 BFG M/T's, 5 speed, MC rear bumper. (Winter DD/ off road fun)
-'95 BMW M3, modded/suspension, sticky rubber, back road monster (Summer DD)
-86.5 Toyota Supra, too much to list. (Never-ending project)
shaeff is offline
Old 03-02-2008, 04:02 AM   #12 (permalink)
hiluxwanabe's Avatar
Anyone ever heard of "MARVEL MYSTERY Oil"? It is supposed to basically do the same as seafoam. I used it on my 97 Saturn( which are well known for burning oil), anyway about 4oz. of "oil" down each cylinder, let sit overnight, stuff rags in holes the next morning(don't forget to mark your wires 1,2,3,etc.),turned it over a couple of times to get rid of any excess. Put the plugs back in fire it up, and Kill any misquito for miles. once the white smoke clears, drive for around 500 miles and do a normal oil change. Worked great on my saturn, ran smoother and got better gas mileage after that. Just thought it might be useful to someone.Cheers.
hiluxwanabe is offline
Old 03-02-2008, 02:06 PM   #13 (permalink)
^ also snake oil.
__________________
shaeff is offline
Old 03-02-2008, 02:17 PM   #14 (permalink)
Brenjen's Avatar
Seafoam hasn't hurt my engine & under my cam covers was nice & clean, just an over all sweet honey color. Of course it could be that I'm a Mobil1 fanatic too. I add my seafoam to the tank & the oil about twice a year; when it's time for a fill up again I change the oil/seafoam & put in a fresh oil & filter change.
All things considered, it's just a solvent but it does what it's supposed to do.
__________________
'95 4Runner 3.0 Automatic bone stock; it's becoming a project slowly but surely, one part at a time
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Brenjen is offline
Old 03-03-2008, 12:15 AM   #15 (permalink)
stormin94's Avatar
While I've had bad experiences with seafoam, I've had nothing but great success with Marvel Mystery oil. You can put that stuff in just about any orifice on your rig that you can think of. I wouldn't recommend it just anywhere, but add some to your gas, or ATF if it's shifting a little off.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Tags
berrymans, cat, catalytic, chevron, converter, damaged, gas, glowing, gumout, red, regane, seafoam, techron, treatment, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Seafoam treatment Nimrod 95.5-2004 Tacomas & 96-2002 4Runners 26 05-02-2008 10:30 AM
PCV location/Seafoam treatment on a Lexus? LSUMatt1514 95.5-2004 Tacomas & 96-2002 4Runners 8 02-27-2007 08:39 AM
high mileage Seafoam treatment? co4rnr 86-95 Trucks & 4Runners 12 02-26-2007 06:55 PM
seafoam treatment question spudrunner 86-95 Trucks & 4Runners 8 12-05-2006 11:18 AM
CEL & VSC\TRAC Lights after Seafoam Treatment on 03' kaneman23 03+ 4Runner/GX470, & 05+ Tacomas 7 09-04-2006 08:38 PM
Content Relevant URLs by vBSEO 3.1.0
2009 InternetBrands, Inc.
